Boost Discrepancy
Old May 6, 2013 | 08:41 PM
justinswrx's Avatar
Boost Discrepancy
So I was running some logs and noticed the boost showing up in the logs is lower than what I am seeing on the live readout while I am driving. 26 psi showing up on the screen vs only 22psi being recorded in the logs. Which should I trust more? Current mods are only a test pipe and the AP running the Stock Intake 93 Oct LWG Stage 2 map.
Old May 7, 2013 | 03:53 PM
COBB Tuning's Avatar
Do you know your firmware and map versions? Is it possible you've updated firmware recently and are on an older map file? If you're using the newest maps you'll need to ensure you have updated to the latest Beta firmware (1.6.7.0-5734) in order for all of the monitors to be accurate.
Marshall@COBB
redSLed
Jan 9, 2017 06:22 PM
blackmambe_evo7
Jul 4, 2016 05:26 AM
HornstarBU
Nov 10, 2010 07:22 PM
Nevonate
Jun 25, 2008 01:55 PM
cpoevo
Apr 11, 2007 11:48 AM
