whats your prefered launch rpm?
Originally Posted by yesevo
try this!
bring it up to 3.000rpm and hold it there ,when the green light comes , press the gas pedal all the way in for like 1sec(where rpm reach 5-6.000rpm) , then let the clutch out fast! (fast slip)
perfect launch everytime i do this way! and i dont smell burn at all...maybe i got act clutch.
dont forget to let it cool between launch! keep practice,,,this is only way to learn.
took a lil while but i found the sweet spot, 3500 range is nice, and i dont dump the clutch, until the cars momentum is up....
this car wont stop impressing me...
Originally Posted by JDM-Spec.com
7500rpm................................. Joking
To me the Evo is not a drag-racing car.
![Off-Topic](https://www.evolutionm.net/forums/images/smilies/offtopic.gif)
Anywayz.......................
I try to do a quick slip around 5000RPMS.
MOTEC STANDALONE?! Where can i get that from?
Originally Posted by megatron
i slip the clutch at 6000 rpms... consistent 1.7x 60 ft's.
![Roll Eyes (Sarcastic)](https://www.evolutionm.net/forums/images/smilies/rolleyes.gif)
I get my best results leaving between 5500 and 5900rpm wot on the AEM EMS soft cut 2step rev limiter. very quick slip of the clutch. I find setting the 2step rpm is the most important thing. If you get the rpm at the ideal spot, the car will pull out of the hole hard with just a hint of tire noise. Engine rpm will not drop down much at all. If you leave with alot of clutch slip to keep the engine from bogging, your probobly at too low of an rpm. Exxcessive clutch slipping is wasting time/distance on the track that your not applying full power. In that case your better off with slightly more engine rpm and faster clutch engagement.
Varrying the engine rpm to suit traction is better than trying to adjust clutch slip.
Thugline
Jun 14, 2016 07:48 PM
Thugline
16
Dec 31, 2015 07:34 AM
