430whp camaro ls1 vs 440whp evo close or no contest
Old May 23, 2005, 02:38 PM
DCSilvrEvo's Avatar
EVO Because..... Lighter car, 1/4mile gears But them things pull when the grip. So I say close
Old May 23, 2005, 04:16 PM
dug-e-fresh's Avatar
430 whp from the LS1 will give it mid to low 11 sec time slips.
If it were an auto, it would run 10s and woop you pretty bad. The 6spd is where he messed up, so count on mid-low 11s @ 122-126 mph.
def
Old May 24, 2005, 03:57 AM
EVO8LTW's Avatar
It's tough to hook up a Camaro with a 6-speed without at least running ET Streets or equivalent. I'd figure that he'll have a hard time doing better than high 1.7s, and even that isn't easy. As far as the rest of the run, how are you making your 440 whp? Is that from a peaky big turbo on low boost, a small turbo on high boost, nitrous? Your powerband will make a difference, espcially if you don't get a perfect launch.
Old May 24, 2005, 05:33 AM
3000ways's Avatar
430WHP=Low 11s/Mid 11s???
What are you guys talking about, with slicks that car (the LS1) will run mid 11s at best and on street tires high 11s/very low 12s. I mean don't get me wrong 430RWHP is nothing to underestimate, but it is not enough power to run low 11s especially in a car that weighs over 3400Lbs.
Old May 24, 2005, 05:36 AM
EvilDylan's Avatar
even if he gets you out of the hole i thin you will walk him down.
he's at a pretty big weight disadvantage
i only had 300 whp and i held off a 380 whp camaro ls1 just this weekend.
Old May 24, 2005, 05:40 AM
ldstang50's Avatar
Originally Posted by XxBLACKMAMBAxX
The Evo's final drive ratio is around 4.56, so you have the advantage there, plus you have the AWD advantage on the launch unless he dead hooks which is rare for drag radials unless you have perfect track conditions, psi, and heat in them. LS1 Camaro is light in the rear as well. If he had slicks there is a better shot of him taking you on the launch. All in all, its a drivers race, you can debate this all day but the cars are so close it will be who can drive better to hit the stripe first.
Perfect points made here. He needs to get his tires up to temp and get them all sticky before he can launch. At the same time, he is launching on an un prepared surface I.E. track. If you can launch you should be able to win this race.
A little FYI when racing him, don't let him launch on his burnout. That is where he will get the most traction. Have him do his burnout then pull up about 2 more feet.
Old May 24, 2005, 05:44 AM
bluevo's Avatar
I'll put my bottom $ on the Evo
Old May 24, 2005, 05:46 AM
3000ways's Avatar
Ok a quick visit over to LS1tech.com has helped me understand a little better, well yeah low 11s are definitly possible with the gears and drag radials, those cars really do hook up well. So I believe it will be pretty close, but I wouldn't be surprised if he took you. This is interesting change, but I believe if you raced him from a roll you would easily beat him, but from a dig you may lose. I guess the slicks/drag radials and the gears are the equalizers for AWD.
You know I don't know, why don't you just race him and let us all know who wins, I hate these threads because the people want predictions, which we give them and never get back to us with the results
Old May 24, 2005, 08:42 AM
XxBLACKMAMBAxX's Avatar
I disagree, from a roll the Camaro will walk the Evo. 2 reasons, instant torque of the V8 gets him moving faster without waiting for a turbo to spool, and RWD has less drivtrain loss and rolling resistance then AWD. From a roll, I say Camaro all the way. Evo has a shot from a stop, which is what I thought this was about. Sorry I dont street race most of my thinking about racing comes from the drag strip.
Old May 24, 2005, 08:47 AM
Cajun Power's Avatar
From a roll (2nd 4k rpm in the EVO) EVO might hang for a while. Eventualy the V8 will walk u. It all depends on the power of the EVO. From a dig going up to 110 (aprox 1/4 mi) the EVO should win if you launch it.
Old May 24, 2005, 08:59 AM
ldstang50's Avatar
I agree about losing from a roll but for slightly different reasons. The Camaro like you said has instant torque and HP unlike the evo cause of its turbo. Yes the RWD has less drivetrain loss, but if i read back correctly the evo has 440whp and the camaro 430whp. That has already accounted for drivetrain loss. If it was 440 crank hp on the evo vs 430 crank hp for the camaro then I would agree, but the evo is putting down more power to the wheels. The camaro also I think would have better aerodynamics. You have this big open frontal area on teh evo for the intercooler while the camaro has a slightly smoother front end
SterlingEvo's Avatar
What about "Chris" (from FL) and his 600whp evo that TOTALLY walked 2 600+whp Cobras - roughly = hp, but the evo runs away:
http://216-55-160-25.dedicated.abac....ead.php?t=6842
^^ link to thread with vids, not the actual vids
Old May 24, 2005, 09:05 AM
Warrtalon's Avatar
500 lbs advantage, and he was pushing more than 600whp due to the boost being set at 35 instead of 30.
Old May 24, 2005, 09:14 AM
ldstang50's Avatar
the only problem i have with that evo is its the 2.3L. The 2.3L can't rev as high as the 2.0L where turbo's like the gt35R start to excel. Granted yes you make it up on turbo spool and more torque, but i'd rather have slightly later turbo spool but have it pull to 9000rpm instead of having to shift at 6800rpm when spool up came in at 3300rpm
Old May 24, 2005, 09:22 AM
en1gma19's Avatar
<snip>...You know I don't know, why don't you just race him and let us all know who wins, I hate these threads because the people want predictions, which we give them and never get back to us with the results
Amen. This is all speculation, anything could happen. Just race him and let us know the results!!!
Quick Reply: 430whp camaro ls1 vs 440whp evo close or no contest
