No 11s yet - update on pump ET/mph and Flash
Old Oct 25, 2005, 10:59 AM
  #31
EVOONYOASS's Avatar
I'm having issues with front wheel hop coming off the line, but I also didn't adjust the tire pressure this time either. Every run I wheel hop and I have to get back into the clutch a little or just pray and keep going while adjusting the gas. Sooner or later I'm going to snap and axle.
When I ran the 12.069 my tire pressure was at 28psi.
To answer the question about mph, I hit a 12.1 @ 117.80 while on C16 and stock injectors.
Old Oct 25, 2005, 11:23 AM
  #32
Warrtalon's Avatar
Originally Posted by EvilDylan
if you slip the clutch the right amount, you wont spin the tires, and you wont burn your clutch too bad. This has gotten me numerous 1.6x 60 foots.
That's my normal method and is how I got my 1.66, but it just wasn't working on Sunday. With the feather/slip method, I got 1.76 and 1.78 (ugh), then with a more aggressive hard-hitting launch, I just spun all the way through first en route to a 1.85 and 1.92. I really just needed more runs...
Old Oct 25, 2005, 11:34 AM
  #33
Turbojunkie's Avatar
what is your target boost on 104 oct? are you setting for a spike or just hitting a psi level, and what psi are running? I too and running a flash with a afc piggy back but have only had one track day to try and dial it in.
Old Oct 25, 2005, 11:46 AM
  #34
Warrtalon's Avatar
I shoot for a steady 24psi in 4th. 1st through 3rd come so quickly that I don't have time to even look, so I just worry about 4th. Since I powershift the 3-4 and am always above 5600rpm, there is no spike. It just hits the boost level I want and sticks, then it starts to slowly taper as I approach the higher rpms. Since I hold 4th all the way to 7800, my boost has tapered significantly by then, but that's ok.
Old Oct 26, 2005, 12:18 AM
  #35
bacalhau16's Avatar
id think that u would be better off with the slipping of the clutch method better, and since u got that new act it should be good for a while. ive tried both types that u mention and the hard hitting launch is always so abusive and if u do it to fast u tend to bog more. atleast if u slip it too much ur rpms stay high, and ur clutch should still hold since its aftermarket. atleast id hope!
Old Oct 26, 2005, 06:59 AM
  #36
3000ways's Avatar
Great Job Warrtalon, 11s are right there, just a breath away.
4TUN8
Sep 7, 2006 12:03 PM
03redtype-s
Jun 7, 2006 06:37 PM
IE Evo
Jun 6, 2004 03:48 PM
midwestmonster
Sep 20, 2003 11:46 PM
Quick Reply: No 11s yet - update on pump ET/mph and Flash
