New times! UNTUNED
Originally Posted by EvoTio
Congratulations on your runs. Those 272's are working really well for you. How is your idle with no tune? I wanted to race so bad, but had to work that day. I hope to be there in April if they are able to complete the new track by then.
Originally Posted by superman105
Nice numbers !!
hey by the way do you work for mitsubishi dealer ?
Originally Posted by EVOfunk
fantastic numbers!
So your car was faster using 91? What was the ET and the trap speed?
Originally Posted by Smogrunner
I'm very impressed!
You think you will make it to the next track day in 3 months?
Hey, what's up Brian! It's Arbi , with the white ix. I haven't asked my friend about the vid, I'll call him right now and see if he still has it. That rain was soo bad man, it didn't stop after you left. We left like 20 minutes later.
Nice times for your mods. Very impressed. Hopefully I will be able to get out to fontana in a few months to see how I am running at a better track then palmdale.
I think 05 stock evo ECUs work pretty good with cams. After I put the cams in, I saw A/F ratio becoming much leaner so that I couldn't lean out anymore. Watch out for the high rpm range( after 7000rpm). It gets too lean sometimes even with the walbro fuel pump( I had to actually add more Maf value with my SAFC). My SAFC is now set near 0 now except around 6000 rpm range.
However, mid range is not that great with stock ECU. I think the mid range will greatly benefit from some tunning. But who needs the mid range on the track?
Originally Posted by matt55
I would have thought that "fuel cut" would have been a factor at that HP . Have you ever hit fuel cut at all on cold nights ? Good #'s with min mods !
