Hunting for 11's..... so close (VID)
Originally Posted by dryad001
This was taken tonight, the guy in the other lane is a co-worker of mine and there were about 10 other of my co-workers there tonight watching as the pounding commenced.
The car is tuned and built by me. I don't consider a tune your own until you actually do it yourself without the help of a "professional" tuner. If anyone wants to see my UTEC maps feel free to drop me a PM
Thanks to laakness for filming me tonight
http://media.putfile.com/dryad001-Hunting-for-11s
R/T .375
60' 1.751
330 5.102
1/8 7.857
MPH 89.85
1000 10.206
1/4 12.156
MPH 115.41
R/T .375
60' 1.751
330 5.102
1/8 7.857
MPH 89.85
1000 10.206
1/4 12.156
MPH 115.41
Sorry didn't ask you. Please stay out of my threads.
And to set the record straight: When you post anything on an open forum, you are subject to anyones opinion, even if you don;t like the person or the comment.
Originally Posted by BigAeVo
mike when did you get rid of the white rabbit? and why did you get rid of it?
nah, I still have it. Hopefully it will be coming off the car in a few weeks depending on Buschurs ship date for a new turbo.
darthfoul- Yup all it will take is a few more runs. The ACT is kinda tricky to be consistant with, it seems that every time I get up to the line the spot where the clutch usually grabs moves around, or it's just me on not modulating the clutch pedal correctly every time.
EVOB23- not really sure on what you mean by 1st to 2nd shift. What else is there I can do? I think I shift fast enough, any other pointers?
A flashed ECU is still a stock ECU. Go ask Scott from TTP engineering...you know 11.2 on "stock ECU."
Anyway, just trying to help. Not sure why Dryad is so bitter towards me or why Silk jumped in with the lewd reference, but there are two truths here:
1) 12.15 is not "so close." It's not close at all if you understand drag racing. Just pointing that out.
2) You're already making the power to hit 11s, and you said nothing about needing practice in the first post before I responded.
If you cannot handle either of these truths, then I suggest not posting. Just trying to help, but it helps if you aren't so sensitive and thin-skinned.
Mack, I also said nothing about how many mods I had and how many mods he has. I went from 12.01 to 12.000. 12.01 is "so close," but even with an improvement in power, I still didn't hit 11s. Comparatively, 12.15 is eons away from 11s...
Originally Posted by EVOB23
I bet you a million dollars if I would drive the car, For damn sure the car will hit 11.8. Thats a promise but you live to far. I ran 12.2 no cams and 112 on pump gas with a 1.73 60ft now its 11.51 at 118mph. Then I drove the same setup as that of the 12.15 and ran 11.88 at 116.32, the first to second is what didn't allow you to enter 11 but the car looks good.
Melvin is a lightweight (130lbs +/-) good driver with a tilton hybrid twin, 280's and TTP-Engineering's camgear settings.
The car has little done to it but exhaust, intake and 110oct.
The ACT is a different animal though and I feel Mike's pain. ****, I don't even attempt to NLTS it anymore.
It will run an 11 surely in short order. Whenever I get stuck in a rut where i know the car can go quicker but I get consistant junk I try to switch something up on the launch or shifts, or even let someone else run it.
My friend was going back to back running consistant 11.3-11.4s on one of our cars. I ran it the first time hitting an 11.1 then 11.0 then 10.9. He got back in it after those runs and instantly hit an 11.1. The faster cars go, the more a tiny little difference ends up being the difference of, in your case, an 11.9x to a 12.1x. Youll hit it soon enough.
You will get your 11's soon!, you got the traps for it.
hehehe, i like this thread. I wish every1 would just put him on their ignore list. It could be like that one south park episode where they all ignore cartman and he thinks that he is a ghost
Thanks fot the motivation. I was playing around last night and the roads were a bit wet so I decided to try out launch control (I have an 03). So I flipped it on and the car lauches harder on wet pavement than I could on dry pavement. I also found out that the UTEC lauch control IS NOT NLTS.
I can make a promise to everyone I will NOT be in the 12's for a year. Next week friday Im heading back down to the track to try again. Now that I have a drag racing map complete I feel I have no reason why I should not be in the 11's.
