1st track run
1st track run
Never even been to a drag track, let alone ran my car. I have launched my car maybe 5 times b4 last nite since I bought it.
05 SSL with megan TP and cat back (factory downpipe) + mail in dynoflash. No other mods. Had spare tire in and ~1/4 tank of 93 oct
tire pressure was 36 front and 34 rear (prolly too high for drag use).
~70F, dont know wind, near sea level.
Ist run, launched at 5K limit with foot to floor. Rolled out the clutch untill started to move then let it all the way out. Revs went to limit with felt like tires spinning (front?). And I think I let off right b4 the last sensor as I hadnt wound out 4th all the way
2.03 60'
5.67 330'
83.96 mph
8.67 660"
11.21 1000'
100.49 mph
13.40
2nd run. Launched at 5K limiter, and let out cluctch as before, but moderated the revs at around 6K (instead of having the foot planted). Less wheel spin this time, shifted at around 7200 rpm every gear except 4th which I wound all the way out
1.91 60'
5.39 330'
86.91 mph
8.25 660"
10.79 1000'
106.8 mph
12.91
Comments? Any idea what the best time I should be able to achieve without addind anymore mods? How where my shifts?
I am assuming race gas wouldnt make much difference without an MBC to up the boost, but I cant mod anymore for a while.
2.03 60'
5.67 330'
83.96 mph
8.67 660"
11.21 1000'
100.49 mph
13.40
1.91 60'
5.39 330'
86.91 mph
8.25 660"
10.79 1000'
106.8 mph
12.91
or it could be a crappy driver The track was not prepped and I did avoid the water box. I estimate I should be aound 280-290 whp assuming 300 whp for an 05 with flash full TBE and MBC 21 psi.
Just thought I could get more constructive help ie need more geip, better launching, shifting. I am as modded as I am gonna get for a while, just wanted to know what I should aim for.
As i am new to this I dont really know how to analyze the slip, hence the post.
Thanks for the help so far, keep it coming
I saw a dude in his C6 get a 13.2, terrible launch , plus an R32 pull a 14.5 after going through the water box.
Some guy with a real jet engine strapped to a large "go cart frame" ran a 6.x at 230 mph. That thing was fooking scary
