Evo vs FD3S
Old May 26, 2006 | 11:52 AM
Kee1pride's Avatar
Evo vs FD3S
I have this *friend* with a 3rd gen RX7 who's always talking about how his car would woop mine.
I don't know how mods but he said he's making about 400whp
I shoulddddd be making around 350whp out of mine.
I have an 05 MR with:
AMS turboback with test pipe
GSC 272/272 Cams
HKS RS intake
Helix o2 Housing
Maxford Exhaust manifold
GRE Performance FMIC
LPI upper and lower IC piping
Forge MBC set to 21 lbs.
Tuned by Dynoflash.
I'm wondering who would win in a drag race (both of us using street tires, no DRs and no Slicks).
He and I live in different cities so please don't tell me "DUH JUST GO RACE HIM", but what do you guys think would happen?
What kind of et's and traps do fd's with 400whp usually throw down?
Old May 26, 2006 | 11:57 AM
Tsurugi-san's Avatar
When he says he's modded, does he mean that he's got bolt on's with a Power FC? Or, is he saying he's gone big single turbo and the works?
Old May 26, 2006 | 12:24 PM
Kee1pride's Avatar
heres his modlist
Engine
BNR Supercars built streetported engine with low compression rotors installed at 86000 miles
BNR Supercars new stage 3 non-seq twin turbos installed at 86000 miles
New wiring harness at 86000 miles
Rotary Extreme V Mount IC with KOYO radiator and Greddy intake elbow
Odyssey mini battery
Apexi Power FC with commander and datalogit (Datalogit not included with sale)
Innovate LM-1 wideband with add on gauge (Wideband and gauge not included with sale)
Jspec Lower Intake Manifold with block off plates
HKS twin power ignition amp
Stock 550cc primary injectors with upgraded 1300cc secondary injectors
Walbro high flow fuel pump
Down pipe, resonated mid pipe & metallic substrate cat, and Apexi cat back exhaust
K&N twin intakes with M2 performance hard pipes
Unorthodox full pulley set, removed air pump
TIAL blow off valve
David Garfinkle torque brace
David Garfinkle Modified y-pipe (all nipples shaved)
SPEC 6 puck clutch
ACT lightweight flywheel (street-lite)
OEM R1 strut bar
XS Engineering high performance dual stage boost controller
Taylor plug wires
H&R Springs
C's short shifter
Jazz catch can - oil vent, pcv valve capped
Stainless, braided clutch line
Stainless, braided oil metering pump lines
Exterior
True '99spec Tail lights
'99spec lower lip spoiler
Feed tow hook
Feed side skirts
Upgraded black turn signals
Rotary Extreme cf bumper cover
Yokahama's road racing tires on the rear
Interior
Replaced tan carpet with black carpet
RX-7 Trix black stock replacement floor mats
Carbon fiber door seals
Defi water temp gauge
Defi boost gauge
Defi fuel pressure gauge
Innovate air/fuel gauge (outer ring matches defi gauges)
Mazdaspeed titanium shift knob and e-brake handle
Rotary Extreme rear strut bar/harness
Alpine CD player, alpine mids, and alpine highs
Old May 26, 2006 | 12:35 PM
Warrtalon's Avatar
Who knows, man? It's all speculation and no way to know or even care unless you can race him.
Old May 26, 2006 | 12:38 PM
Kee1pride's Avatar
Trust me. It will happen someday. Regardless, no one can answer me at all about what kind of traps fd's with 400whp are getting? =\
Old May 26, 2006 | 12:39 PM
2muchboost's Avatar
He's got a lot of $$$ in that car. Good driving should get him 11.5 in the 1/4 mile...
Old May 26, 2006 | 12:46 PM
nirvevo's Avatar
"(all nipples shaved)"
That had to hurt
:-D
Old May 26, 2006 | 12:51 PM
Spaceball 1's Avatar
Both go to track, get the time slips
Old May 26, 2006 | 12:54 PM
Kee1pride's Avatar
how in fudks name is an fd with only 400 to the wheels and street tires going to hit 11.5.
Old May 26, 2006 | 01:10 PM
Mario's Avatar
Originally Posted by Kee1pride
heres his modlist
Engine
TIAL blow off valve
SPEC 6 puck clutch
OEM R1 strut bar
Taylor plug wires
H&R Springs
C's short shifter
You will win if you are running at the track and on street tires. But be aware that he is going to be closing in on you rather quickly, as you cross the 1/4 mile mark. BTW, PM me when you set up a date to run him. Thanks.
Mario
Old May 26, 2006 | 01:19 PM
Kee1pride's Avatar
It could be a while but sure thing
Old May 26, 2006 | 01:24 PM
pjsevo8's Avatar
Dude, FD's are one of the lightest imports period... they only need about 500rwhp to hit 9s with a good driver! You will get eaten alive if he can drive.... sorry to say.
PJ
Old May 26, 2006 | 01:32 PM
Kee1pride's Avatar
like 2700 lbs. thats pretty light but thats nothing rediculous. plus you're still not factoring in street tires.
Old May 26, 2006 | 01:36 PM
pjsevo8's Avatar
dude... most likely he cant drive it.. It seems like a very hard car to drive.. one of my best friends Carsey has one that is nearly stock right now and he can keep up with us Evos easy.. but if he can i think it would be game over...
PJ
Old May 26, 2006 | 01:39 PM
nolancer's Avatar
i got my money on the 7. if u guys race from a dig then you might have a SLIGHT CHANCE. from a roll if he's definetly got you man.
Quick Reply: Evo vs FD3S
