Traps and ETs don't match
#62
Originally Posted by SKILMATIC
Well if that were the case you would know that evos dont run low 12's and high 11's stock. Even warr will tell you that. You havent been in the racing world that long cause if you had you would have known that.
Also you said
That is totally different from what you are claiming now which is still wrong.
You will put down consistent low 60's and et's with a launch limiter. This has been a proven fact here in the racing world since day 1. However, with your experience in the racing world I am suprised you still dont grasp that concept.
And again rnr does not have a lunch limiter!! How many times do I have to tell you or is english your second language which it prolly is since you are in mexico?
Stock evos run high 12's to low 13's depending on the year and trim. Again I am suprised with your racing experience you still didnt grasp that fact either.
Again stop your BS lying cause you will not last long here.
BTW What do you suspect u run in your Evo in the 1/4 mile? I would say at least 12 flat. U are on the stock turbo? Yes! So is it safe for me to say that stock turboed Evos run high 11s and low 12s? Go read my post Mr. Special. Stock turboed Evos run high 11s to low 12s( u can't deduce with supporting mods and a good tune). My bad I forgot u were intellectually challenged and Globally Impaired. Do u agree Corky or is it Forrest. OUT!
#63
Originally Posted by IE Evo
Like I said before u have a reading comprehension problem and are Special. Who said anything about a launch limiter or better known as launch control. Get your terminologies right. I said Rev limiter set at only 7500 Rpms will limit your potential Ets and mph on a 35 R equiped car. At 493 whp, a 35R equiped car without a flash eliminating fuel cut above 7500 rpm is not going to be able to use the extra power in the upper RPMs. The potential of significant improvements in Ets and mph is not going to be attained in the 1/8th and in the 1/4 . With the rev limiter set at 7500-7700 124-125 mph is about all you can expect for trap in the 1/4. Also the lag between shifts due to short shifting out of the power band can't be good for 1/8-1/4 mile times and Mph.
BTW What do you suspect u run in your Evo in the 1/4 mile. I would say at least 12 flat. U are on the stock turbo? So is it safe for me to say that stock turboed Evos run high 11s and low 12s. Go read my post Mr. Special. Stock turboed Evos run high 11s to low 12s. Do u agree Corky or is it Forrest. OUT!
Second of all, this has nothing to do with trap speeds at the 1/4 this has to do with explaining that better driving techniques will rendor him better traps and et's and 60fts in the 1/8 which will give him an even better 1/4mile run. You keep saying "the gt30 and 35r turbo applications can't rendor low et's in the 1/8 because the turbo has too much lag." While I keep coming at you with proof that your wrong you keep avoiding it and bringing up things that dont have to do with the discussion.
I will say it again. A GT30 or 35r turbo application should be running faster 1/8 mile times and 60fts. I am sure once you perfect the launch you will acheive this. There is nothing wrong with your setup. Just shift faster and perfect that launch. Thats the only thing you have to do.
#64
I picked it up for $26k. Great car except for the springs and tires. I'm really happy with the purchase.
I know it went an 11.5, but that was at Sac Raceway, at sealevel. I'm tellin you, crappy track. Imagine LACR but worse. It's usually about 5500ft corrected altitude.
#65
Also, I dunno what happened, but we could only get 27psi with the boost tables maxed out. So we couldn't break 500 like I wanted, but whatever, car is still fast.
#66
welcome too driving a big turbo car i'm trying to learn also i trap 120mph & run 12.0's all the time my 60ft is 1.8's 1/8mi about 89-90mph...
after watching the videos of my car if you get your 1-2 shift down you will drop .2-.4 off your time that is where my problem is.. hang in there you will get it.
#67
#68
Forget it man you are pointless. Stop trying to cover you ill informed posts by taking my good advice and adding it to yours.
#69
In car video is still coming...dunno when though. But someone finally got some vid of me at the track friday night and posted it up. This wasn't my best run of the night, but the launch was average for me. It's good to be able to sit back and watch it. I think my 1-2 shift can be alot faster. Seeing how much the nose dives.
http://members.***.net/joelynch15/Da...derson_754.mpg
#71
I managed several 7.52s, I think I can get a 7.3 with a traction. How did it look? What I realized I'm doing is slipping it very slowly at first, and it engages higher than I'm used to. So it builds up boost, then I end up just dumping it and spinning them. If I go quicker with the clutch I end up bogging it.
Evil_1
May 7, 2006 05:26 PM
03redtype-s
72
Feb 28, 2006 10:08 AM
