Need some help.
Need some help.
Hit the track last night and here is my best time . Some people whith same mods are hiting mid 11s . what am i doing wrong? BTW this was done on c12 and 26psi afr10.00 R/T...706 60...1.82 1/8...8.185 MPH...85.6 1000...10.711 1/4...12.81 MPH...107.76
Should do 5-6 more mph on straight 93 with 23psi. Some of the mods are just overkill and do nothing for you (280 cam, cam gear, injen intake, invidia o2, Ti exhaust), but even the basic mods should make way more power. Maybe it's a case of just getting too many mods and making it too complicated by spending too much unnecessary money. Did you run when stock to get a baseline? Did you run with minimal mods to see progression? If your only data point is NOW after all those mods, then there's no way to know if your car was weak from the factory, if the cam and gear messed it up, if there are major boost leaks everywhere, if your driving is poor and includes extremely slow shifting. There's just no way to know any of this without more data.
This is what i was hiting all night long on pump gas. 60...1.777 1/8...8.338 MPH...82.96 1000...10.928 1/4...13.099 MPH...105.07 on,22psi no boost leaks 1st,2nd and 3rd the car feels strong 4th not to much shifting at 7000 rpm
just for comparison i have an o3 evo with less mods my mph was 113,i dont know turbotrix told me the opposite they have to tune the car for race gas other wise it will run extremly rich.
Also SILVER9, your time and traps are way off pace in my opinion and it's not just the heat. I can understand if you ran on straight pump gas and lower boost, but something is wrong. The heat may take away two to three miles, but that still would put you at 109-111MPH in cooler weather which would be just decent for pump gas (still should be faster), but not decent for race gas and 26PSI. Somethings wrong, I think some parts on your car aren't all they are cracked up to be, but still you should be a lot faster. You should have a 11 second car with good driving, and a lot higher trap speeds. Again something is wrong.
basicly everything silver has minus the intercooler piping,and not as an aggresive cam,and no 02 housing. i have the 264,272 cams turboxs frontmount exedy clutch flywheel hks down pipe,no cat with the rsr exhaust it is 3.25 inches very loud and annoying at times and perrin intake.on an evo 8
359 to da wheel on turbotrix dyno
