fastest stock bottom end evo?
Old Sep 20, 2006, 02:59 PM
TrinaBabe's Avatar
I have ran my car at 34-36psi on the street while testing crap out... so yes people do that on the stock motor
My ignition had no amplifier when I did run it... it was completely bone stock with BR8ES plugs gapped at anywhere from .022-.028
I now have the DSM ignition on it and it holds fine at 35psi at least. I am going to try to get it to run for one more day at the track this year. The problem is I will be running it for the first time on straight methanol so Im not really sure how it will work out. Hopefully I make it before the tracks close down.
Old Sep 21, 2006, 06:05 AM
Ang Wen Yan's Avatar
Unhappy
Can you please dyno one time everthing is ok.I am going to grt flamed if i use horsepower computer(Physic).Hope to see you hit 650whp or 700whp and run low 10 or posible 9 on straight mentahol and stock block.
Old Sep 21, 2006, 06:34 AM
EVOMIZ's Avatar
what is needed to run the dsm ignition?
is it a plug and play?
Originally Posted by diambo4life
Have you thought about running a DSM ignition? They work better than your stock EVO stuff you know. I have 2 local buddies (11 sec EVOs) who converted and they have been happy with the results so far.
blackevolution8
Sep 25, 2010 08:39 PM
excessiveboost
Evo X Dyno Results
Dec 14, 2009 08:52 PM
2003evo8
Jan 24, 2008 07:27 PM
PHILLY EVO
Nov 29, 2005 06:33 PM
lancaholic
May 22, 2003 02:35 PM
Quick Reply: fastest stock bottom end evo?
