Same full weight Evo IX goes 121.66 mph
Old Apr 10, 2007, 09:26 AM
  #46
JVELA's Avatar
Keep the good work. (el carro esta que estilla). 121wph with stock turbo and full weight with a lot of sh&t on the trunk, that's a hell of a tune. Siga para adelante mi pana
Old Apr 10, 2007, 09:29 AM
  #47
kouzman's Avatar
Originally Posted by Blue Evo 8
Kouzman,
do you have a link to the calculator?
Here's the link. You have to dload a small Excel file... Its very easy to use!
http://www.gearboxman.co.uk/inforatios.html
Old Apr 10, 2007, 09:32 AM
  #48
thatguy's Avatar
Originally Posted by kouzman
i used a calculator to see the max speeds at a 7800 rev limit and a 8000rpm rev limit in both stock dimensions and bigger dimension tires...
7800rpm limit
1. 235/45-17 = 118 mph
2. 245/45-17 - 120 mph
8000rpm limit
1. 235/45-17 = 121 mph
2. 245/45-17 = 123 mph
Definitely is doable on the IX
At 8k no ARP studs? Springs/retainer?
Old Apr 10, 2007, 09:44 AM
  #49
kouzman's Avatar
Well, i don't know my friend... Its not my car that did this ET...
Personally i have studs...
Old Apr 10, 2007, 07:49 PM
  #50
Big Dube's Avatar
any info on a car with 255/45/17 and the max speeds the car can run in 4th?
Old Apr 10, 2007, 08:03 PM
  #51
kouzman's Avatar
255/45-17
7800rpm in 4th - 122
8000rpm in 4th - 125
ALWAYS according to the gearbox calculator i posted before...
Old Apr 10, 2007, 09:09 PM
  #52
thatguy's Avatar
Kouzman,
Can you PM me the gear ratios for the evo ix?
This calculator is great thanks for the link.
Old Apr 11, 2007, 06:42 PM
  #53
kouzman's Avatar
Kouzman,
This is from Mitsubishi's website!!!
2006 EVO IX RS & GSR
1- 2.785
2- 1.950
3- 1.444
4- 1.096
5- 0.761
F- 4.529
very useful indeed!
Old Apr 11, 2007, 06:49 PM
  #54
EvoM Administrator
Noize's Avatar
Tire Diameter 25.32677
Final Drive Ratio 4.529
1st Gear 2.785
2nd Gear 1.95
3rd Gear 1.444
4th Gear 1.096
5th Gear 0.761
1st Gear 2nd Gear 3rd Gear 4th Gear 5th Gear
RPM MPH RPM MPH RPM MPH RPM MPH RPM MPH
2500 15.0 2500 21.5 2500 29.0 2500 38.2 2500 55.0
2600 15.6 2600 22.3 2600 30.1 2600 39.7 2600 57.2
2700 16.2 2700 23.2 2700 31.3 2700 41.2 2700 59.4
2800 16.8 2800 24.0 2800 32.4 2800 42.7 2800 61.6
2900 17.4 2900 24.9 2900 33.6 2900 44.3 2900 63.8
3000 18.0 3000 25.7 3000 34.8 3000 45.8 3000 66.0
3100 18.6 3100 26.6 3100 35.9 3100 47.3 3100 68.2
3200 19.2 3200 27.5 3200 37.1 3200 48.9 3200 70.4
3300 19.8 3300 28.3 3300 38.2 3300 50.4 3300 72.6
3400 20.4 3400 29.2 3400 39.4 3400 51.9 3400 74.8
3500 21.0 3500 30.0 3500 40.6 3500 53.4 3500 77.0
3600 21.6 3600 30.9 3600 41.7 3600 55.0 3600 79.2
3700 22.2 3700 31.7 3700 42.9 3700 56.5 3700 81.3
3800 22.8 3800 32.6 3800 44.0 3800 58.0 3800 83.5
3900 23.4 3900 33.5 3900 45.2 3900 59.5 3900 85.7
4000 24.0 4000 34.3 4000 46.3 4000 61.1 4000 87.9
4100 24.6 4100 35.2 4100 47.5 4100 62.6 4100 90.1
4200 25.2 4200 36.0 4200 48.7 4200 64.1 4200 92.3
4300 25.8 4300 36.9 4300 49.8 4300 65.6 4300 94.5
4400 26.4 4400 37.8 4400 51.0 4400 67.2 4400 96.7
4500 27.0 4500 38.6 4500 52.1 4500 68.7 4500 98.9
4600 27.6 4600 39.5 4600 53.3 4600 70.2 4600 101.1
4700 28.2 4700 40.3 4700 54.5 4700 71.8 4700 103.3
4800 28.8 4800 41.2 4800 55.6 4800 73.3 4800 105.5
4900 29.4 4900 42.0 4900 56.8 4900 74.8 4900 107.7
5000 30.0 5000 42.9 5000 57.9 5000 76.3 5000 109.9
5100 30.6 5100 43.8 5100 59.1 5100 77.9 5100 112.1
5200 31.2 5200 44.6 5200 60.3 5200 79.4 5200 114.3
5300 31.8 5300 45.5 5300 61.4 5300 80.9 5300 116.5
5400 32.4 5400 46.3 5400 62.6 5400 82.4 5400 118.7
5500 33.0 5500 47.2 5500 63.7 5500 84.0 5500 120.9
5600 33.6 5600 48.0 5600 64.9 5600 85.5 5600 123.1
5700 34.2 5700 48.9 5700 66.0 5700 87.0 5700 125.3
5800 34.8 5800 49.8 5800 67.2 5800 88.5 5800 127.5
5900 35.4 5900 50.6 5900 68.4 5900 90.1 5900 129.7
6000 36.0 6000 51.5 6000 69.5 6000 91.6 6000 131.9
6100 36.6 6100 52.3 6100 70.7 6100 93.1 6100 134.1
6200 37.2 6200 53.2 6200 71.8 6200 94.6 6200 136.3
6300 37.8 6300 54.1 6300 73.0 6300 96.2 6300 138.5
6400 38.4 6400 54.9 6400 74.2 6400 97.7 6400 140.7
6500 39.1 6500 55.8 6500 75.3 6500 99.2 6500 142.9
6600 39.7 6600 56.6 6600 76.5 6600 100.8 6600 145.1
6700 40.3 6700 57.5 6700 77.6 6700 102.3 6700 147.3
6800 40.9 6800 58.3 6800 78.8 6800 103.8 6800 149.5
6900 41.5 6900 59.2 6900 80.0 6900 105.3 6900 151.7
7000 42.1 7000 60.1 7000 81.1 7000 106.9 7000 153.9
7100 42.7 7100 60.9 7100 82.3 7100 108.4 7100 156.1
7200 43.3 7200 61.8 7200 83.4 7200 109.9 7200 158.3
7300 43.9 7300 62.6 7300 84.6 7300 111.4 7300 160.5
7400 44.5 7400 63.5 7400 85.7 7400 113.0 7400 162.7
7500 45.1 7500 64.4 7500 86.9 7500 114.5 7500 164.9
7600 45.7 7600 65.2 7600 88.1 7600 116.0 7600 167.1
7700 46.3 7700 66.1 7700 89.2 7700 117.5 7700 169.3
7800 46.9 7800 66.9 7800 90.4 7800 119.1 7800 171.5
7900 47.5 7900 67.8 7900 91.5 7900 120.6 7900 173.7
8000 48.1 8000 68.6 8000 92.7 8000 122.1 8000 175.9
8100 48.7 8100 69.5 8100 93.9 8100 123.7 8100 178.1
8200 49.3 8200 70.4 8200 95.0 8200 125.2 8200 180.3
8300 49.9 8300 71.2 8300 96.2 8300 126.7 8300 182.5
8400 50.5 8400 72.1 8400 97.3 8400 128.2 8400 184.7
8500 51.1 8500 72.9 8500 98.5 8500 129.8 8500 186.9
Old Apr 11, 2007, 06:50 PM
  #55
EvoM Administrator
Noize's Avatar
IX on 235/45/17 above.
Old Jul 8, 2008, 11:30 PM
  #56
Inprogress's Avatar
What effect would a larger tire have on the finish at the track? I'm running 245/40/18, would that give me more slack in terms of being able to finish in 4th?
Old Jul 9, 2008, 05:43 AM
  #57
Warrtalon's Avatar
Yes, a TALLER (not necessarily larger) tire will give you taller gearing and thus more room to run in 4th. I am using the exact same tires as this guy now - 245/45-17 Nitto 555R - and am crossing the traps 300-400rpm less with the same trap speeds. I'm sure you could put my previous tires (255/40-17) and the new ones into a calculator to determine the exact rpm savings, but I knew that I didn't want to be revving so high in 4th at this altitude, and I needed extra traction, so I went with this size/type. Use online tire calculators to determine exact diameter differences between different tire sizes. 245/40-18 is actually 1% taller than 245/45-17, so you should have a good bit more room in 4th than stock. However, remember that your speedo is reading LOW when driving on the street...
Anyway, I know this thread is over a year old, but 3000ways make a very good point about the trap going WAY up without the ET going down even with a good 60'.
Old Jul 9, 2008, 07:39 AM
  #58
Inprogress's Avatar
Thanks for the clarification warrtalon and the help, i appreciate it.
Old Jul 10, 2008, 12:04 PM
  #59
Turbojunkie's Avatar
Ive gone 122.13 and 122.32 and consistantly 120-121 with R1A's. they were the stock size. 235-45-17. just replaced them becuase they were bald as hell. new size is 245-40-17 fedral cheapies. let ya know how those do when i get the car back. when i went 122 i was at 8k rpm
Old Jul 10, 2008, 12:06 PM
  #60
Warrtalon's Avatar
VIII 4th gear is much taller.
Quick Reply: Same full weight Evo IX goes 121.66 mph
