My RNR 50trim times from GLD
#34
I disagree with the comment that a 50 trim can not max out the power of the 4g63.. when you are into the 500 whp range you are maxing the capability of the 4g63... I should know, I was best friends with AMS for the last 3.5 years and spent many many hours talking with them. I was one of their first 500 whp 50 trim owners..
#35
I disagree, also 500WHP is VERY VERY hard to get out of a 50 trim, and even if you do, it isn't beyond what the Evo 4G63 can handle daily. 500WHP is fine. Many shops of course reccomend a build, but they are also..
#1 Venders
#2 Like to optimize everything
One should know that it is almost impossible to build a motor that has the tolerances from the factory. I Believe Cosworth and Jun are the only I know of too exceed this. I know of far more blown "Hey it's built yo!!!!!!1" motors Vs. OEM, there is a reason for it.
#37
#1 Venders
#1 Venders
#38
Nice run!!!
All you midwest guys in here- check out www.midwestevos.com we're growing quick!!! Mighty midwest has the fastest evo's in the country!
#40
Well, I disagree with you. 500 whp is pushing it on a stock motor. I think AMS would know what they're talking about. 2003lancerevo8 and I both hit 500 whp on AMS' dyno. (499.xx @28 psi for mine, and I think 2003lancerevo 8 hit 497.xx, correct me if I'm wrong) AMS is not about dyno numbers like most shops. They give you a safe tune and we both respect their opinions on how far you should push the stock block.
Again, As good as AMS is, they are also a Vendor. They would want you to buy a Built 2.0 or a 2.3. 500WHP is NOT pushing the limits of the 4G63. It just isn't, otherwise the 4G63 would be pointless. Sean Ivey has been running close to 580WHP on PUMP/Meth on his 2003 Evo for what, 2 years? It hasn't poped, and 500WHP won't pop a motor given a properly sized turbo and proper tuning.
dtrackstar
Nov 11, 2012 07:56 AM
DG Motors
Aug 19, 2009 05:37 PM
BostonEvo
Oct 4, 2007 09:10 AM
