12.018 @ 115.00 MPH dammit
Old Oct 13, 2007 | 10:59 PM
mcwop23's Avatar
I tried but I'm going to give in and install a few more bolt-ons/get a race gas tune finally to make sure I get my 11s. Had a couple of 12.15 passes with 1.79x 60's before "hooking up" with a 1.728 on 25psi in all tires. Still not launching like I used to for some reason. Ran 103-octane and 25Psi on my 93-octane tune.
breakdown:
60' - 1.728
330 - 4.987
1/8 - 7.726
MPH - 87.91
1000 - 10.051
1/4 - 12.018
MPH - 115.00
oh well
Old Oct 14, 2007 | 07:44 PM
mcwop23's Avatar
Can anyone speculate on why it seems like my 1/8 mile traps are always so low compared to what everyone else is running? My car isn't breaking up or knocking or anything and I seem to still trap pretty high in the 1/4 mile for my mods.
Old Oct 14, 2007 | 07:51 PM
JRB_EVO's Avatar
Maybe your 1/8 mile trap speed and ultimately not achieving the full potential of the car because you are extending your shift points beyond the optimum point, which causes you to run in a gear when the power is already falling rapidly!!!
Old Oct 14, 2007 | 07:58 PM
Warrtalon's Avatar
Shift points would be my guess.
No sympathy for you, though, until you hit 12.000 like me.
Old Oct 14, 2007 | 07:59 PM
bluebyu36's Avatar
wow oh so close
mcwop23's Avatar
i actually think i shift early if anything but you may be right. I know sometimes it's hard to gauge that 1 to 2 shift while launching/spinning. I'll definitely look at that more closely though.
Old Oct 14, 2007 | 08:00 PM
mcwop23's Avatar
according to this graph where do you suggest i try shifting? I try to hit 7000-7100 generally
Old Oct 14, 2007 | 08:01 PM
Warrtalon's Avatar
Could be too early OR too late - if you had some logs, we could do an analysis. I actually shift the 1-2 much earlier than the earlier gears (~6500rpm), because it seems to run out of breath much more quickly after a full boost nasty launch, but the later gears I do around 7100 (stock cams at sea level).
Old Oct 14, 2007 | 08:02 PM
Warrtalon's Avatar
Ohhh, very nice and smooth curve that stays even up top. Not sure how you manage to do that on the stock turbo especially with the tight gearing (what gear is that?), but based on that graph, I'd do 7200-7300rpm.
Old Oct 14, 2007 | 08:03 PM
pac74's Avatar
your oh so close bro.
Old Oct 15, 2007 | 03:43 PM
mcwop23's Avatar
i'm pretty sure it's a 4th gear pull. I'll try wringing it out just a bit further next time for certain, and I'll bring the laptop along to log this time. It was too crowded to experiment, got 4 runs in the whole night.
Old Oct 15, 2007 | 03:49 PM
Qatar_Evo's Avatar
i belive that your only problem is your 1/8 speed
coz my 1/8 speed was 85.61 so you should be alot more then me
warr is right i guess shifting is you problem
Old Oct 15, 2007 | 03:50 PM
mcwop23's Avatar
also the lower graph was my mail-in dynoflash and the curves are pretty damn identical other than the HP/TRQ numbers
Old Oct 15, 2007 | 03:51 PM
mcwop23's Avatar
on my 12.003 i did trap 88.66 in the 1/8th, and that ended up being 113.98 in the 1/4 on a hot day.
Old Oct 15, 2007 | 03:57 PM
evo@24psi's Avatar
Dude i feel ya!!! I hit numerous 12.0* Before i hit my 11's. Before i read down i was thinking your 8th time was little high. Mine was a 7.61. Seems like you made up for it hitting 115 though. I ran 114.83. Dont get frustrated, it will come. Ohh and i did mine on pump. haha j/k man!
Quick Reply: 12.018 @ 115.00 MPH dammit
