New Stock Block MPH record!!!
My buddy Emery from Streetuned...just called me from the track he just ran a 10:685 @ 134.5mph!
That was on his first pass with a 1:7 60 ft!
He is turning the boost up and hopes to break the ET record as well.
He is a good driver and does all the work and tunes his car himself....some of you might remember his car if you were at the BR shootout in Norwalk. his is the real clean Blue car that was parked next to the AMS trailer and our White Evo with the blk AMS sticker.
GO Emery!!
GO Emery!!
BTW they have the White one down there to see if they can get into the 9's
With those traps, depending on the weight, it would be at least 550whp on a Dynojet uncorrected. Could be upwards of 580 even. That power has been made on the stock block, but that power has never been put to the ground to the tune of 134mph, nor has it held up for long before exploding. This is impressive work.
They are on there way home from the track and that was his best pass off the day ( only got three in ).
Emery has been working on 4g63 motors for a long time. He has always kept a low profile until he opened his shop and website.
http://www.streettuned.org/index.html - check it out
He is also a sponsoring vendor here and is finally getting some long overdue attention that he deserves.
His car is DD and he drove to the track today ( 30 miles ). He maintains my car since it came back from AMS and he is the only one I trust to work on my car in this area for sure.
BTW this was the last day the track will be open till spring
He should be posting on here soon.
10.61@131.59mph.
Emerys 10:685 @ 134.5mph!
He only missed the ET record by a very small amount but I guess he put a stamp on the MPH record for now.
Wish he could have gotten a few more passes in today.
why do you say blow up? i mean my friends car is making over 550 at 35 pounds on a gt35r...
he runs 25 pounds daily...puts in 100 octane and runs the meth an turns the boost up to 35 lbs. at the strip..
turns it back down when he leaves..
motor is fine
