Quest for 11s on pump turned out dissapointing
So I hit the track tonight and there was definately something wrong with my car. I ran a 12.7 @103 then I lowered the boost to 22 and rolled out and ran a 13.1 @105. I am on the stock clutch so maybe the clutch was slipping or maybe the car was just knocking every gear up top. Here is what the timeslip looked like.
R/T........... .028
60'..............1.74
330'............5.115
1/8..............7.994
MPH............84.19
1000...........10.535
1/4..............12.701
MPH.............103.23
I am trapping less than a stock IX. help guys please.
R/T........... .028
did you feel the knock, was timing being pulled? The car could have been running to lean and pulling timing especially top of third and fourth. I had this problem once I ran a 12.2 at 100 (no power top of fourth). Good luck.
I don't think it is knock. Your 1/8th mph & trap are what they should be based on your ET at that point. Your 60 is ok and you could improve on that some. But I really think there is something holding the car back. I would do a boost leak test for sure!
Actually the 1/8th ET is really not that great because something is wrong. The car has the power to trap at least 88 in the 1/8 it is going 84. 60' is what it is because of a limited stock clutch, I do not launch off the two step for that reason.
I'm saying the 7.9 @ 84 mph is about right. Meaning that the 84 mph 1/8th trap would give you about a 7.9 in the 1/8th. If the car normally traps 88 mph in the 1/8th then as I said earlier there must be something up (boost leak, etc..).
