Best tire pressure on Advan A046
Old May 27, 2008 | 02:48 PM
Dannievo's Avatar
Well if you guys are running on these tires what is the best tire pressure (PSI) to prevent a wheelhop
thanks, Daniel.
Old May 27, 2008 | 04:35 PM
Warrtalon's Avatar
There is no set pressure, and wheel hop is not only related to pressure - it depends on the track surface and how you launch. I typically run around 20-22psi in order to avoid breaking traction with 6000rpm launches and ~350whp, but sometimes that's too low if the track is very sticky. Last Friday, it was still too high as the track was so slippery that I was burning all 4 through 1st gear. I wasn't willing to drop my tire pressure to FWD slick pressures, though.
Start at 30 psi and work down from there.
Old May 27, 2008 | 05:53 PM
StreetThisEvo's Avatar
22 psi hot.
TwinTurboM3
Apr 16, 2016 01:57 PM
Parikh1234
27
Oct 13, 2014 06:46 PM
Evoixjohn
Jan 15, 2012 12:23 AM
oldscholevo
Apr 11, 2008 01:23 PM
camMCLEAN
20
Mar 6, 2007 06:31 AM
Quick Reply: Best tire pressure on Advan A046
