Drag Strip Video Links HAPPY LABOR DAY
I think we all wished the quarter was closer, but this track was fun. I have to figure out where my boost went, couldn't get over 18 pounds of boost for some reason. I started to pull on the Camaro in third and my 60fts were consistent on each run.
need t check your lines and see if there is a leak somewhere maybe anyone have any ideas to help him out the figure out what is wrong
I just finished pulling the lines from EBC; found that shop that replaced clutch put lines on backwards from vacuum and waste gate to solenoid. One of the lines also had a small crack at connection to solenoid. I'll find out how it does tomorrow and try and dial boost back in. Hope that was all that needed to be replaced and checked all the other connection are hard pipes and are tightened as far as I can without ripping connections.
