Another attemp! And a record broken!
Well We got out to our local track yesterday and tried again. We went a 10.0 with the boost down a little bit. This is the best and one of the last passes of the day before it got rained out.
http://videos.streetfire.net/video/S...ile_182357.htm
This was done on 33 lbs and a 1.6 60 foot.
here is the slip
-Emery
here is the slip
-Emery
You can say that again! A motor that's never been apart is stock, unless you count cams as a 'built set-up'. Emery keeps setting the bar higher and higher.
What's the current weight of the car? I know you mentioned before that you had no intentions of going crazy with weight reduction.
1 Post
for instance Fathouse has a stock motor: stock turbo, stock cams, stock ecu, stock mas, stock head
that's a stock motor
