12.44 at 110 with 1.80 60ft.
i shift around 6500 RPM in 1st and 2nd. 7000 in 3rd.
I was around 20psi because only hitting 210load abouts throught the whole run. now im going to boost the hell out of it, 27psi and 24psi redline and see if I can get around your times. I got 30/70 meth/water.
I shift 7k 1st to 2nd, 7500 2nd to 3rd and to 4th. Turn up your boost a bit and experiment with shifting a bit higher 1st to 2nd. When you start shifting lower, you'll bog down a bit and take more time to build boost again. If your running meth injection you should be running faster than 13's. Lower your tire pressure and try getting your 60fts. down and see what happens. Although I can't really say much, my best 60ft to date is only a 1.76...
Chris P.
Dec 1, 2017 09:07 AM
