HTA86 Twinscroll Track Results
Plain white evo with a small wing, you would never know it was about to lay the smack down.
Car is super efficient at 29psi. I think all the parts mesh well and the results speak for themselves.. Judging from the logs, I would say that with some shifting and staying in boost better between gears a 136-137mph pass is not far off. **** it already did 135.8 Car is a beast.
Junior
Junior
It depends on a lot of factors. Larger turbos are more efficient at 30 psi than smaller turbos, therefore the charge temps are lower. Also, larger turbos normally mean larger headers and turbine housings, this means less back pressure, which also can help fight detonation. Plus many other factors. Basically there is no rule of thumb that says X amount of boost pressure for Y amount of octane. Every car/setup is different.
Freddy302
66
Dec 25, 2016 09:49 PM
Freddy302
May 19, 2010 07:47 AM
AssaulTECH
EvoX 'For Sale' Suspension / Brakes / Handling
161
Feb 24, 2010 04:13 PM
Freddy302
40
Oct 10, 2008 06:05 PM
