11.4@116 FP Red IX
Old Jul 26, 2009 | 10:15 PM
GGevo921's Avatar
11.4@116 FP Red IX
So i finally made it to cecil county this year with my new fp red turbo setup. Car was running on 93octane pump gas and makes about 427whp on 24pounds of boost. The tires are Falken all season tires that have maybe another month of life set at 20psi in all four corners. car went 11.4 @ 116 with me missing 5th gear at just as i hit the 1000ft mark. first time ever had to shift to 5th at drag stip.
Mods:
Fp Red turbo 63mm inlet Not 80
Buschur Stage 5
Cosworth M2 cams with buschur springs and retainers and Arp headstuds(only motor work on car)
Buschur Ported IM
Buschur 65mm TB
Buschur Ported and Jet Coated exhaust manifold
Buschur SS 02 housing
Exedy Twin Disc HD and SS clutchlines (only drivetrain Mods)
Stock ECU, Stock Block/head, Stock Evo 9 Trans, Crushed stock Bov
Al dynoflash tune to 427whp
Time slip breakdown.
60' ... 1.720
330 ... 4.787
1/8 ... 7.340
MPH ... 95.97
1000 ... 9.532
1/4 ... 11.409
MPH ... 116.09
Im hoping i can get a low 11 out of the car on pump gas and then itll be time for the race gas and 10 second pases. let me here some opinions as well as any suggestions for setup at the track.
Old Jul 26, 2009 | 10:22 PM
EvoFredo's Avatar
man thats good. btw
what type of suspension are you running.
Old Jul 26, 2009 | 10:30 PM
GGevo921's Avatar
Originally Posted by LVmevo
man thats good. btw
The whole suspension is factory. Im thinkin about buying the Awd motorsports D2 coilovers in combination with the buschur side diff support and mustache bar...some day. But im all stock suspension as the car sits.
Old Jul 26, 2009 | 10:35 PM
4g63evoeight's Avatar
you should be running that mph with the stocker.
however your ET is good for that mph.
Old Jul 26, 2009 | 10:36 PM
DDATuned's Avatar
Get that 60ft down and you could get that 10sec pass on 93 oct.
Nice job.
Old Jul 26, 2009 | 10:45 PM
GGevo921's Avatar
Yea i thought my mph was low too. i thought id trap about 119 or 120 but i missed 5th and coasted all the way through the traps. I think that def killed my mph.
Nice job.
Thanks. im workin on that 60 ft, i think a little more seat time and i could cut a high 1.6. id really like to see a 10 on pump gas. im going again this friday if weather permits.
Old Jul 26, 2009 | 11:46 PM
PeteyTurbo's Avatar
I would expect 120 out of your car with clean shifting.. I was trapping 96th in the 1/8th as well and hit 120 shifting to 5th with the six speed. Although I was on the stock turbo so you may pick up a few more mph then me.. I need to get out to cecil
BTW all season tires are the next best thing to drag radials..
Old Jul 26, 2009 | 11:50 PM
Domolution's Avatar
Damn, that is NOT bad....if you up the boost a bit, i think you can get 10's no problem.
Old Jul 27, 2009 | 12:09 PM
StreetThisEvo's Avatar
No need to shift to 5th your only going to
slow your times. Good job and keep at it.
Old Jul 27, 2009 | 12:35 PM
TakaseEVOIXSE's Avatar
its the shift to 5th gear (or lack of) that caused the MPH to drop... its not reflecting your true mph potential. Obviously since you ran an 11.4 its got an easy 120+ in it. Just the stock gearing sucks... i go the same problem... just have to rev it out to 8500 from what i hear or get a taller final drive (ideal) to make the gears longer.
Old Jul 27, 2009 | 06:11 PM
GGevo921's Avatar
Thanks im hopin to cut a 10 this frday if i can get a better 60ft. but i have to shift to 5th i run out of 4th gear at 8000rpm at the 1000ft mark. my rev limiter is 8000rpm.
yea i no that 5th gear miss killed it. was first pass out in the new setup. yea the stock gearing suks, i wish i had the buschur trans with longer gears. but i want to see what i can get out of the stock trans first.
Old Jul 27, 2009 | 06:28 PM
EVO8LTW's Avatar
Nice driving.
macspeed702
Oct 14, 2010 08:55 AM
AcePitcher11
Nov 23, 2009 09:52 PM
BURNALL_4
Jul 31, 2007 09:30 PM
Jrod@Buschur
Apr 30, 2007 10:29 AM
AlwaysinBoost
Oct 14, 2006 06:56 PM
Quick Reply: 11.4@116 FP Red IX
