evo x traction problems
evo I've got the same issue with mine. My two step is at 6500, I'm spinning like a bandit upon launch and am dealing with 2nd gear lock out myslef. I'm going to replace my x front rotors and callipers for a set off an 8 and drop a set of 17's on the car with some drag radials and see where that takes me.
I am having some issues with traction as well. 6,000rpm launch seeing 8-10psi off the line. I do have good tires Toyo R1R's which are very soft, but the stiff sidewall isn't helping I guess. I will probably try my snow's out at the track in the spring to see if they make a difference off the line. The sidewall's are so much softer it's like a luxury car now.
Also, are you guys messing with the tarmac, gravel, snow settings? What seems to be the concensus for drag racing?
