evo x traction problems
I went to the track this week & ran into some serious problems.I just changed over my whole set up & make some more power & I am blowing all 4 tires off & I have no traction.Car has 19inch advans on falcon tires & I even have custom drag coilover with springs & I just can not hook. Car goes sideways everytime I lauch the car & I even lowerd the tire pressure & when the tires spins I have major problems putting the car into 2nd gear what can be my problem
Swing by the shop Tomorrow and we will play with a few things..Your car is up some serious torque from before so we have quite a few adjustments we need to play with before your next outing
If you remember correctly I set your 2-step up for 6,600rpm and roughly 15-17psi off the line(street settings you needed)...If I knew you were going to the track I would have lowered the 2-step to 6,200 and 10-12psi off the line and we could have worked it up or down from there with tire pressure adjustments.
Sorry the rims are 18s not 19s & I can not but smaller rims on it because I need a small break kit 1100$ after I get that then I can buy slicks or a smaller better rims & tires so I can drag race. 400wtq does feel nice thoe
