Dave Stock / Speedtech Evo 9 runs 8.70 @ 163 mph
#31
Cheers mate. it was a handful that's for sure. I had a similar experience on my first shoot deploy. (that is the first ever deploy) I was snagged to the other side of the track. pretty well shaken from that. lol but obviously happy with the 8.73418@163.05
The 8.706@162.96 felt smooth as.
but yea in the last run i really didn't want the rear end to get to far ahead of itself. it brought back memories of the CBR rx7 at Meremere last year.. So had to man up and keep my eyes open to ride the drift section out..
Hopefully with a few shoot adjustments Meremere will be a lot smoother as its not so forgiving at that end of the track.
#34
Cheers mate..
No it was a combination of getting to know what to do with a chute and trying to get it locked down straight away, and having the chute mounted below the centre of gravity..
I was told to power into the release then to start braking.. but no.. i believe i buttoned off too early and upset the flow of everything, causing the rear to lift up, locking the brakes, and some what sh*t'n myself..
It all happened so fast up until the drift section. then it felt like everything was in slow motion. hope'n like hell a tire wouldn't give way/or hook under the side load..
#35
Cheers mate..
#36
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
#42
![Thumbs up](https://www.evolutionm.net/forums/images/icons/icon14.gif)
![Mitsubishi Logo](https://www.evolutionm.net/forums/images/smilies/mitsu_logo.gif)
Engine:
Mitsubishi 4G63 Turbo
2.2 Litre Tomei billet crankshaft
Custom billet aluminium conrods
JE Pistons (Custom STM spec)
STM competition balance shaft removal kit
Baffled alloy sump
HKS head gasket with STM O-Ring kit
STM Drag spec head studs
Ported cylinder head
STM Drag spec cams
Solid lifters
Competition double valve spring kit
Oversize stainless valves
HKS adjustable cam gears
HKS cambelt
Mechanical cambelt tensioner
Hypertune plenum with 90mm throttle body
Turbocharger:
Garrett GT45 based turbo with Tial Sport exhaust housing
Turbosmart 60mm wastegate
Custom stainless STM headers with full merge collector
100mm stainless exhaust
100mm intercooler
80mm aluminium intercooler plumbing
Turbosmart raceport blow off valve
Drivetrain:
PPG 4 speed dog engagement gearbox
Ikeya Sequential shifter with custom air shifter system
Quarter Master triple plate clutch on custom flywheel
DSS stage 5 axle kit (front and rear)
STM transfer case
Wheels:
15x7” Rays TE37 rims
24.5 x 8 x 15” MT drag slicks
Brakes:
Lightweight Wilwood 4 piston callipers front
Lightweight Wilwood 2 piston callipers rear
Lightweight scalloped rotors front and rear
Hydraulic handbrake
ABS removal
Linelock system for staging
Electronics:
Motec M400 ECU
Motec SDL sport dash logger
Motec E888 expansion unit
M&W PRO Drag 4 CDI
Sparktech CDI coil-on-plug system
Fuel System:
12 Litre fuel cell
Twin SX 1000 HP fuel pumps
SX fuel pressure regulator
HKS fuel rail
1600 cc injectors
Body:
Lightweight fibreglass doors
Modified front chassis
Fibreglass bootlid
6 point NZDRA spec rollcage
Racetech seat
5 point harness
#43
Dave,
Pull that chute just before the 66' trap box at the end of the track, as you've probably figured out by now it takes a second for the air to fill up. When it finally does, I just clutch the car into neutral and stay off the brakes until the car is settled into the aerodynamic braking. The chute slows the car down pretty fast at 165+ for a second, then its much safer to start getting into the brakes.
Be safe out there. Getting the car up to 170 mph is the easy part, slowing it down in a short distance can get quite tricky!
