EAVWIDL runs 141MPH on street tires
This car was built by Maperformance and tuned by me. It also was the first stock ECU into the 800's. https://www.evolutionm.net/forums/ev...stock-ecu.html
So we decided to run at the Nyce1s North vs South this past weekend, but it rained all day in Fayetteville so we headed over to Rockingham to see how the car was running. I want say thanks to Robbie, Justin and Babi over at Epic/Forced Fed Performance for the dyno runs! As there heartbreaker dyno reads pretty low with the car making 662 and 519 uncorrected and 681 and 534 corrected and went 10.59 at 141 on a 1.85 sixty foot and backing it up with a 10.54 at 135 with a 1.71 sixty foot with a slow shift to 4th. Im pretty sure the car would have gone 10.2 at 143 with a faster shift to 4th. I am pretty mad at myself for not hitting the gears better.
We also have Hooisers for this car but the owner forgot the spacers at home (Jamie) I can say it should go 9's with some good sixty foots on the Hooisers.
All runs where done on Pump E85
http://www.youtube.com/watch?v=kk8VFkwhNrM
glad we could help out and sorry we couldnt get out to rockingham with you guys. We will hit a track day together sooner or later.
Good runs guys trapping 140 on street tires is impressive
Nice runs! With better shifting and better 60ft's that will be a low 10sec high 9sec car!
BTW do you have some valve stem seals leaking on you? Noticed some smoke on decel and after your burn outs.
A little better run from last night. Should have had our 1st 9 sec. pass forgot to set rev. limiter back up. If you listen you can hear it before the car crosses line.
http://www.youtube.com/watch?v=mOo1u2nRYzM
