Hoosier Drag Radials
Hi maybe someone can be so kind to help me , I have a Evo 9 and I have the 245 R17 hoosiers, I use 24 psi tire pressure, but if I go over the vht I get wheel hop , so I go on the side were there is only concrete with no rubber on the starting line because Im afraid of breaking something. My 60 ft is 1.70 and the car goes 10.7 @ 134 mph car weights 3370 with me.
Should I put less tire pressure and go over the rubber with track bite?
thanks for your input, I havent dynoed my car but it has the hta3586 with everything and e85 , I will try again , with less pressure and in the vht. and put more boost, Im at 30psi now.
Just remember. The lower in tire pressure you go. the more chance for breakage and wheel hop. There is fine line between spinning and hooking up just right. Start at 20 and let more out each pass. Every driver leaves the hole different also
Like these AMS offers
http://www.amsperformance.com/cart/A...-Bushings.html
BDecker9
10
Sep 21, 2012 09:34 PM
Clipse3GT
Jun 21, 2010 07:29 PM
