post yor 1/8th mile times
Old Aug 21, 2004, 04:47 PM
specialk22oz's Avatar
i was wanting to see everyones 1/8th mile times and what mods were done
my times are a 11.86 in stock 4cyl automatic lancer oz
Old Aug 21, 2004, 11:14 PM
Wizard_of_Evo's Avatar
7.82@88.44mph - vishnu stage 1+
Old Aug 22, 2004, 01:25 AM
IE Evo's Avatar
Stage 1+ seems very consistent so ditto or close enough to the Wizard. Done several 7.8 and low 7.9s. Too lazy to look up exact #s. So Ditto and Smog,Evotomig are probably in the same ballpark.
Old Aug 24, 2004, 02:37 AM
Corey's Avatar
My best time was a 8.6 @ 82 mph with a 1.9 60 ft. That was with a HKS rs intake, HKS downpipe, and HKS carbon-ti cat back. I was running with my 18" Volks so I'm sure that was hurting the 60 fts. That was back in May when it was cool out.
I ran a 8.6 @ 80 mph with a 1.8 60 ft. with the mods listed above plus a Perrin cat delete, Walbro 255, Hallman MBC set to 20.5 psi, and a Dynoflash. This was done in the middle of July when it was over 90 degrees outside and still on my 18's.
Old Aug 24, 2004, 10:11 AM
EvilDylan's Avatar
8.1 @ 85
Old Aug 31, 2004, 07:37 PM
boostfed's Avatar
first pass ever in my evo tonight I cut a 8.90 @78mph with .755rt and 1.92 60-ft. second pass I let off the clutch a little fast an is spun the tires then bogged. but I gained a mph in that run. I'm not gonna bet on mine to much. I've got a little smell out the clutch on my second pass. just a little hint of clutch nothing major. hope to be able to hit 8.70 with a little better 60-ft and a mbc.
-Chad-
Old Aug 31, 2004, 07:46 PM
evotomig's Avatar
Yep, 7.84@88.37
Old Sep 2, 2004, 08:12 AM
rebelzx's Avatar
8.2 @ 82 mph. No top-end at all though without cams. I only picked up 22 mph in the back 1/8 and went 12.9 @ 104.
EDIT: With cams, went 7.869 @ 86.4 mph at the Evo vs. WRX shootout.
Old Sep 13, 2004, 06:05 AM
Stinkapuss's Avatar
7.81 @ 88.21
Old Sep 13, 2004, 07:12 AM
Smogrunner's Avatar
7.89 at 87 mph
Old Sep 13, 2004, 07:28 AM
jj_008's Avatar
8.73 at 85.88mph w/ 2.15 60'. Vishnu stage 1+.
Old Sep 13, 2004, 10:48 AM
ldstang50's Avatar
7.96 @ 85.3 mph on a crappy 1.72 60' i'm usually in the 1.65-1.68 range
Old Sep 14, 2004, 08:27 PM
boostfed's Avatar
how the crap do yall cut such good 60'fts. my best so far is a 1.88 that launching at 5700-5800rpms. anymore rpms then that and I spin. the track I go to only gets preped once a week and is raced on the 3 days a week. I'm gonna try to find a better track. if I can't do any better then I'm just gonna stop dragracing. I use to be able to cut 2.0? 60-fts in my 99 Civic Si. I don't get any nasty clutch smell and it is not slipping. I trap 79.7mph tonight on my second pass. and my time was a 8.94. my 60-ft was 1.94 cause I try to launch at 6000rpms and it just spun and then bogged. does it matter that my car only had a little over 2000 miles. I just can't get the hang of launching my car. I'm just gonna have to try another track and see if I can't do a little better. If I could turn a low 8.80 or 8.7? I would be happy. I can't image what it's like to cut a 1.65 60ft. the local hillbillies would sh*t a brick if I was out launching some of them with slicks. hahahha I can't wait to get my tb exhaust.
-Chad-
Old Sep 14, 2004, 08:32 PM
UFO
UFO's Avatar
8.3 @ 85.4, 20 PSI & DynoFlash thru-the-mail.
Old Sep 14, 2004, 10:46 PM
stage 2 update - 7.63@90.26 - untuned on 93 octane - 1.77 60'
Quick Reply: post yor 1/8th mile times
