Best shifting points?
Originally Posted by plokivos
actually the optimal point of shifting is 6800 rpm on slightly modded evo's.
it'll give you the optimal range of power.
but with cams and bit more high end power with a tune, you shift high as you can. I look at my RSM after the runs, i see 8000rpm.
i was shifting 7500rpm + and was trapping 106 at best and gave shifting 7k a try and started to trap 108 even 109 in one run. so i think its best shift at 7k if you don't have cams.
i guess i left out if you're not tuned. there's really no need to go up to the redline on not tuned evo with slight mods (catback, etc.)
1st and 2nd gear bring it up as high as you can JUST before redline, shifting fast and , when shifting into 3rd bring it up less then 2nd, and into 4th if you do even less then 3rd, and make sure you shift rather smoothly, not neccessarily fast, this will help you keep a good trap speed. 1st and 2nd are set up gears, if you do those right, 3rd and 4th are just for trap.
I'd beleive in shifting b/f redline if you don't have the boost taper. However, once that is fixed, I'd say take it to redline. I don't have a dyno to back me up, but the car obviously does not stop pulling after 6500 like it used to. Probably b/t 7k and redline is the best.
Shift points are no mystery ... do the math. Your optimal shift point is determined by combining your gearing with your torque curve. To see an example of the math for our Evos, go HERE.
l8r)
l8r)
Shifting style really doesn't matter. For example let's take a 3-4 shift on a stock Evo transmission. Shifting at 7000rpms has you going ~83mph ... now during your shift your car bascially coasts and really doesn't lose much, if any speed. So let's assume you're still going 83 mph as you hit the gas again in 4th ... 83mph in 4th gear puts you at ~5100 rpm. Whether you let your rpms drop during the shift, or whether you shift while never lifting off the throttle, you will still end up at 5100 rpms in the next gear. RPMS and gearing and speed have a fixed relationship. The most important thing to consider in figuring out where your shift point is (assuming stock tranny), will be the power curve of the car.
Of course, if someone has problems shifting at the optimal point, because they can't get it into the next gear (i.e. the dreaded 1-2 shift for a lot of Evos), that's a much different issue altogether...
l8r)
l8r)
I agree that shifting speed makes a difference as far as spool goes, as a matter of fact, if you go to a NLS system (no lift shifting), your stock turbo should never drop below 10psi with mediocre shifting speed and it'll stay all the way up at ~17psi if you shift fast. Keeping your turbo spooled and the fast shifting will also have a significant effect on your ETs. Going from regular shifting to NLS can drop your ET by as much as .5 seconds.
However, the rpms still don't change and your power curve also doesn't change. If you were to datalog your drag runs, you would see that the rpms will be very close to the calculated numbers. They may vary +/- 100 rpms depending on how much you let your clutch slip and the state of your tires, but that will be about it. The fact that you stated that you are never below 5600 rpms during your non-inhibited runs, supports this point, since shifting close to redline will put you right around, if not above 5600 rpms (depends on the gear). Incidentally most modded Evos should be shifted as close to the redline as possible for maximum power. My optimal shiftpoint with an AMS 3071 currently resides between 8000 and 8400 rpms. The gearing is also why the fastest drag Evos rev to 9K, or even 10K rpms.
l8r)
l8r)
l8r)
l8r)
I do datalog my runs and I _don't_ shift at redline. I shift around 7200, but then am never below 5600 in the next gear when doing my fast shifting method. When I had to shift slower, even though I shifted at the same rpms, I went all the way down to 5300 in the next gear. That made a HUGEEEEEEEEEEEE difference and was all due to slower shifting.
This is contradictory to what you wrote earlier, though. If people in Evos with stock turbo and stock cams were shifting at redline, that would completely go against the earlier "power curve" argument, because we hit peak HP before 7k and have a major drop-off in power 7500.
I also agree that faster shifting will make you go faster ... no denying that. If your shifting consistently has you slightly ahead of where the gear-ratio normally falls, then you might even be able to squeeze another tenth or so by going back to a dyno plot of your car and looking to see if you wouldn't be better off shifting slightly higher or lower.
Care to post your datalogs? I'd be interested in seeing a real-world example of what we're discussing. Also, how high do you keep your revs in between shifts?
l8r)
