Rev matching?
Rev matching in an Evo is easy as hell. I got it damn near perfect during my test drive.
Just pay attention to your RPMs when you downshift normally. That way, when you go to rev match, you should be able to remember what RPM the engine went to when you did a normal downshift. It'll get much easier the more you do it. Give it a week or two, and you'll be doing it off of sound alone.
Originally Posted by Tonz of fun
Then when you get good at that you can use downshifting to slow your car down when going a 120 on freeway off ramps. Then your breaks will thank you.
If not can you explain?
Thanks.
its when you blip the throttle when downshifting to match the engine RPMs to the rpms of the gear you are going into.
1) it hardly spins the clutch, slippign the clutch to downshift will wear the clutch much faster
2) its smoother than slipping the clutch
3) it enables you to downshift faster than slipping the clutch
its a very good technique for even the street
BTW someone noted that they used downshifting to slow themselves down. This is not a good idea. The whole point of revmatching is so that when you downshift there is no jerking motion, either causing acceleration or braking. The brakes should be used for braking, your transmission is much better at changing gears. Changing out brake pads and rotors is much more cost effective than changing any driveline part.
if i rev too high, it seems like the rpm's just settle down for the gear i'm trying to downshift into... feels like butter when you hit it dead on! Can't say i would want to do without rev matching haha... just gives you a better feel for the car and passes the time in traffic.
Originally Posted by Kronik
Rev matching in my evo is 1k for ever gear. If you are in 4th and you down shift to 3rd -- say 4k -- you need to rev to at least 5k.
But anyways, I'm going to incorporate rev-matching technique into my daily driving starting now. The hardest part is knowing what RPM you need to dump the clutch at.
It was suggested the best way to memorize the RPMs is by sound through the downshifting method of slowly release the clutch. I hope this is right b/c I'm going to use this method to learn.
How long do you think it might take to properly learn this techique and comfortably use it daily?
Originally Posted by mdosu
unless they changed the gearing for the 05 5-speeds...in my 03, it seems like I need a bit over 1k to rev match correctly on a downshift...oh about 1200 or so.
It is advantageous to know how your motor sounds during the rev range -- the more you are used to the sound the easier you can pick this up. But going back to your question -- you are cruising down in 4th gear around and want to down shift to third -- the easiest method I can tell you is: clutch in, blip throttle, release clutch immediately. It's not a "dump" perse, it's a gentle release and if you have blipped the throttle enough, upon release the car will not jolt. It should be a smooth transition. Just give it some more practice and you will get used to it.
On another subject -- left foot breaking while driving. That's fun! heh. Good luck!
do you guys do this and also double clutch?
" Not double clutching when you shift"
Vin Deisel talking to dude after a drag race
I don't think he was joking, I think he just had bad writers. I'm trying to say it's pointless to double clutch in modern vehicles and that "do you guys do this and also double clutch?" was a stupid question.
