Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
Does this waste gas?
Old Dec 19, 2007 | 12:42 PM
Profoxcg's Avatar
Originally Posted by Mr. Stock
If you let the car coast IN GEAR, with your foot off the accelerator, the ECU goes into fuel cut mode and no gas is being injected into the engine. You can actually feel the fuel come back on if you let it get down to around idle, depending on the elecrtical load.
this causes a lean condition in the cylinders and therefore my EGT temp start to drop?
the thing that is curious is that at iddle my EGT is at 950F and while coasting they drop down to 600 or lower untill the car stalls i guess
Old Dec 19, 2007 | 12:55 PM
EvoBroMA's Avatar
we have a winner! all modern fuel injected cars cut fuel when you're coasting in gear. putting it in neutral wastes gas, but leaving it in gear with your foot off - uses no gas. (with the exception of throttle hang on the 05+ LOL)
Old Dec 19, 2007 | 01:20 PM
Mr. Stock's Avatar
Nada, there's no combustion whatsoever as there's no gas. Lean conditions can actually RAISE your EGT's. Your EGT's drop because the only thing entering and leaving your combustion chamber is air.
Old Dec 19, 2007 | 08:07 PM
wizzo 8's Avatar
This is true and when it gets to low the idle will kick in and you will feel the car bump forward. You will also notice the air/fuel gauge show rich instead of lean.
Old Dec 19, 2007 | 08:12 PM
MRadjahoe's Avatar
Very true! it does that with most fuel injected cars. But you will notice when it gets to idle the car does sorta maintain its speed 3mph or whatever it is.
TURBO_S2K
26
Dec 10, 2016 09:53 PM
VT Mitsu
Nov 8, 2016 11:02 AM
mitsuevo803
12
Jul 9, 2008 09:44 PM
Evolution2003
14
Jul 6, 2007 01:04 AM
J!n K@z@mA
Jan 19, 2006 02:55 PM
Quick Reply: Does this waste gas?
