Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
what does dropping clutch to launch damage
Old Dec 16, 2007, 08:15 PM
incandescent's Avatar
Originally Posted by edardnaekim
iam fasting rite now, no spoolage for me.
aww man you are in a dry spell. you need to get ur ***** wet sometimes man let that clutch slip baby! im cracking myself up dude seriously
Old Dec 16, 2007, 08:16 PM
edardnaekim's Avatar
you should have no prob blowing the tires off either now cus its soo cold, so be ready to counter steer
Old Dec 16, 2007, 08:18 PM
DRFTKNGG's Avatar
Hope you have deep pockets buddy...lol.
Lots can go wrong...clutch, snap an axle. Bust your Transfer case.
That's why you build it to take the punishment. Like engine bushings and suspenion bushings to try and keep everything in it's place under hard launches. A clutch that will get the job done and not be overkill.
The factory clutch is a wear and tear item and is not covered. As a tech, I know when I see a clutch that has been abused. Heat causes bluing, glazing. Your done...hand over $1600...lol
Old Dec 16, 2007, 08:19 PM
haha
since you want a rush...make sure you do said launch while turning you will SURLEY POOP yourself. and maybe destroy your evo i dunno i almost did the first time i lauched on a turn. I was like awd FTW it is almighty. LOL little did i know ...that thing whipped out like a ****. bring a change of underwear!
Old Dec 16, 2007, 08:38 PM
izabran's Avatar
if u plan to dump clutch on a evo.... i hope that you are a baller.... because that transfer case is 2900 from the dealer that tranny is 2500 from the dealer that clutch job is 1800 from the dealer.... have fun hope u have deep pokets
Old Dec 17, 2007, 12:39 PM
Jeff_Jeske's Avatar
On the stock clutch you can pretty much dump it. On anything else you have to be a bit more civilized and walk it up at a decent pace removing driveline slack and not shocking the system.
In most cases an aggressive launch will result in wheel spin. Sometimes it will result in wheel hop. Wheel hop is very dangerous.
Old Dec 17, 2007, 12:41 PM
JordanS4's Avatar
the stupidity in this thread is mind boggling
Old Dec 20, 2007, 06:38 AM
sillyrpm's Avatar
it sounds fun...makes me scared to do it...my pocket aint deep enough..
Old Dec 20, 2007, 11:19 AM
NurSpecSupport's Avatar
start launching conservatively. Slowly move to launching more aggressively. Once you smell your clutch burning, back off.
As everyone stated above me you have to pay to play.
Old Jan 16, 2008, 03:29 PM
godmiller10's Avatar
if you lose your clutch why would you go back to stock? just get a good aftermarket
Old Jan 22, 2008, 09:11 PM
johnnyblazeusmc's Avatar
same ishh happened to me, now my clutch is not grabbing.. i step on the gas and it revs before it actually speeds up causing my turbo to spool up after 3600 rpms then my car just launches so i dont have a normal cruising speed anymore until i get a new clutch. dont even go for a new stock clutch just get yourself a brand new ACT clutch or Clutchmasters clutch for around $500 bucks.
Old Jan 23, 2008, 07:06 PM
Scawt's Avatar
Old Jan 23, 2008, 07:11 PM
EVOlution561's Avatar
Originally Posted by spdracerut
Basically it shocks the entire drivetrain: Clutch, gears, transfer case, motor mounts, all the bushings in the suspension, axles, driveshafts, rear diff.
You do it enough, any and all of those things will fail prematurely.
Very well put, you should never drop a clutch. Always slip it quickly.
Old Jan 23, 2008, 07:13 PM
wizzo 8's Avatar
If you want to play you will have to pay. If you cant afford it dont launch it!
Quick Reply: what does dropping clutch to launch damage
