Cold (and Fishtailing) Return to Las Vegas
Let me start off by saying, yes, I posted on the same topic last year. This appears to only be a problem when it's cold here in Las Vegas - exiting a corner in 2nd gear under boost (totally stock car) creates a wild, fishtailing, tail-happy Evo for me.
If you're not from around here, you know our roads are slick - most of the time, when I break traction there's *no noise* (or warning) from the tires. This is very creepy.
Interestingly enough, the same turn at the same speed in 3rd gear under boost doesn't produce nearly as bad of a result. Is it just because the power ramps on so much more aggressively in 2nd gear under boost? Is the solution simply to drive less aggressively?
I would sincerely appreciate being taught how to rectify this so that I can have normal cardiac function while driving in the cold.
There's no snow on the ground (although it did snow last night), no ice, and no water. Just the standard Vegas slickness combined with the cold.
It's quite the buzz kill as you never know where the limits of the car are so I absolutely *creep* along in the turns.
Thanks in advance!
BoostLover99
Thanks in advance!
BoostLover99
I've never slammed the gas on in a corner and I'm deathly afraid of what might happen (intuitively, coming from 10+ yrs of FWD cars) if I do.
Stay out of boost...wrong gear if you want to stay in control...put 200ibs of sand in the back like the rest of the folks with Snow/Ice issues and hope for the best.. So you better undertsand...the roads a slick because of oil on the roads and slight condensation on the roads surface mixing with the oil...making a slick track.. Good luck...
BoostLover99
Nov 17, 2007 11:58 AM
