Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
Rev-Match downshifting
Old Apr 27, 2008 | 10:20 AM
inco9nito99's Avatar
Do you guys blip the throttle once or twice? Random question as i've seen both and tried both, just seems twice is more involved for "speedy" transitions. Although in general twice results in a smoother transition.
Old Apr 27, 2008 | 10:29 AM
evokel's Avatar
once i believe?
but its alittle bump
Old Apr 27, 2008 | 10:32 AM
4WS Tuning's Avatar
twice 5th to 4th
once 4th to 3rd
twice 3rd to 2nd
Old Apr 28, 2008 | 08:48 PM
ttt for more opinions. Tamer, you drive a cheetah you have no gear shift :P.
Old Apr 30, 2008 | 11:09 AM
mikebutler's Avatar
why not do 1 long blip instead of 2
Old May 1, 2008 | 08:11 AM
madmax199's Avatar
If properly done it should only require one blip, however the lenght of the blip or more precisely the load applied on the throttle is going to vary depending on the speed(mph) and the gear(5th-4th/4th-3rd etc).
More speed require more load(longer blip) as well as a lower gear change.
You just need to develop a feel for it, but if it makes anyone sleep better at night, the evo is the best production car I've driven in terms of pedal placement and seat position in relation to the pedals, heel toe downshifts are basically idiot proof in the evo compared to most cars.
Old May 4, 2008 | 01:55 AM
MATT@WORKS's Avatar
Originally Posted by 4WS Tuning
twice 5th to 4th
once 4th to 3rd
twice 3rd to 2nd
Why would you ever blip twice? I think people are misunderstanding the idea behind blipping. You should just blip it once for each gear, if it needs more revs, just hold the gas longer.
Old May 4, 2008 | 07:27 AM
nothere's Avatar
matt, you are prolly correct, the two blip thing is left over from driving cars with bad syncros. Blipping with clutch pedal down (1), and in neutral, clutch pedal up (2), the one in neutral is to spin up the trans gear for a smooth gear engagement. The other blip is to spin up the motor to the gear.
modern well designed syncros make it unnecessary to do, but its like wearing a belt and suspenders in a day when most kids rely on I don't know what to keep their pants up.
you know what, I can't tell you how I do it, but I do when ever I can on the road course.
Old May 4, 2008 | 07:33 AM
DonHugo's Avatar
Agreed but the stock pedals are kinda small for those of us with narrow feet. I cannot reach the gas in my driving shoes, I need to get some pedals to fix that.
PS I only blip once
Old May 4, 2008 | 07:53 AM
cfdfireman1's Avatar
Bend the gas pedal over a bit to the left or get new pedals or both. 1 blip
Old May 4, 2008 | 08:59 AM
RevRevGone's Avatar
You should only need 1 blip! Just go out and practice more. Get use to your clutch and the exact point when it engages. This will help speed your shift up!
Old May 4, 2008 | 10:18 PM
MATT@WORKS's Avatar
Well that's double clutching-- that's different, that should still involve only 1 blip though with more time after the blip to allow the gearbox to go back in. It has to be REALLY high for that to allow it to drop to the correct rpm. This takes a TON of practice with the specific car v. just practicing on any car to learn how long it takes you to knock it in from neutral. The only time you'd have to blip twice would be if you took too long to make the move or miscalculated the delay.
Double clutching is the ONLY WAY TO IMPROVE RELIABILITY OF A GEARBOX WHILE SHIFTING. People have told me before that rev matching saves a tranny but they're wrong because you're still spinning up against the syncros to engage the next gear. Fast downshifts and high rpm differences ruin transmissions. If you have an older Evo, learn to double clutch or just drive like everyone's mom and put in the clutch when you want to slow down.
Old May 4, 2008 | 10:21 PM
itzcharlez's Avatar
practice makes perfect =]
Old May 7, 2008 | 01:35 PM
spumoni1984's Avatar
perfect takes years
Old May 7, 2008 | 04:08 PM
4WS Tuning's Avatar
Idk thats just how my foot works lol I blip the same amount of time everytime, and do it without thinking. I always do it twice, i find it easier than holding my foot down.
When it comes down to it, its all preference.
Cheers!
Quick Reply: Rev-Match downshifting
