launching
given your on the stock ECU, have the clutch pushed all the way down, bring the RPM's up to 5,000, within a second or two the ECU will realize its in 'launch mode', once in lauch mode give it a few seconds to fully build the boost, then slip the clutch a little and boom your off. have fun, be safe, and dont break your transfer case
If your evo is modded and you bought it that way there's a good chance the previous owner had the 2 step raised, stock is around 5k rpm from what I've been told. Mine is tuned and set to 6k as well. Launching your car properly is highly dependant on the way it's set up. Do you have high performance tires on the car?(i.e. falken rt-615's/yokohama advans/dunlop star specs/bridgestone re-01r's) Or do you have a softer sidewalled tire like an all season(kumho ecsta asx/toyo versado, etc.) Are they stock width or are they wider? Do you have super stiff coilovers/springs or stock suspension? How much power is the car making? Stock clutch or upgraded?(6 puck, twin disk, triple disk)? Bigger turbo with more lag? These all need to be considered when launching the car to do it right.
Generally speaking launching an evo with the 2 step is fairly simple, the last step changes based on the way your car is configured. It goes like this:
- Make sure the car isn't moving
- Hold the clutch to the floor
- Engage first gear
- With the clutch still fully depressed and the car in first gear, floor the throttle. The revs should rise and stay at a pre-determined rpm(i.e. 5k, 6k, etc.)
This is where it gets tricky. Depending on how much power your car has and what kind of clutch you're using, you may have to do things a bit differently here. There are several methods I've heard of that have all worked for the people that used them, including myself.
One way to do it is like this:
-With the clutch still to the floor and the throttle floored as well, slowly back off the clutch until you feel it start to grab and chatter a bit, then sidestep it to let it engage fully and off you go. This was the method a friend of mine used on the stock clutch with minor boltons and summer tires(sticky ones), and a mid 5k rpm 2 step, and is generally considered the correct way to launch.
Another way to do it would be to just dump the clutch the way I did, which worked for me because of my less grippy tires, weak clutch, and power upgrades. I'm making a bit more power than stock(340 whp) and still using the stock clutch, so this wasn't as damaging to my drivetrain as a similar attempt with summer tires and a twin disk clutch would have been.
A more powerful clutch will grab harder and be less prone to unintended slipping at launch, but at the same time must be intentionally slipped initially using the first method I mentioned or there's a good chance you will break something. For example, completely dumping an Exedy Triple Carbon clutch on a set of racing slicks with only mid 300 whp will most likely result in your transfercase going boom. Grippy tires without enough power to spin them causes wheel hop at launch, which is pretty bad for your drivetrain. An ideal launch involves a little wheelspin to prevent damaging shock to your transfercase, transmission, axles, and differentials.
A third way to launch your car would be to not use your 2 step at all and simply feather the gas a bit while feeling for the right release point as you slowly raise the clutch from the floor. Some people actually prefer to launch the car this way as it allows the turbo to build boost a bit differently. If you have a bigger turbo on the car that's laggier, your launch must be adjusted accordingly to compensate for this so you don't bog down as soon as you're off the clutch. If you could tell us more about your setup maybe we'd be able to help you out a bit better.
Hope this helps, I'm by no means a guru but I've had my fair share of launches and figured I'd share what I know.
- Engage first gear
Hello interesting info.....
alot of my friends broke transfer cases upon launching, mostly they had ralliart twin disc clutches
some has 2.3 +Greens
other 2.0 + red
Any advice on th best way of launching to avaoid what happened to them in the future?
BTW, i heard there is some kind of device you can install to control your launching, any info abt that?
Thanks!
Daniel
other 2.0 + red
Thanks!
Daniel
Launching is simple.
Step 1: Stop
Step 2: Push in the clutch
Step 3: Put the car in first gear
Step 4: Let the clutch out to find where it engages and hold it just before that (it'll make it easier to slip/dump)
Step 5: Floor the gas, and hold it to the floor. You will start bouncing off the 2-step at 5000rpm and build around 10psi.
Step 6: DO NOT let off the gas pedal at ALL, slip out the clutch until you feel it grab, then let go.
Step 7: DO NOT let off of the gas pedal until you shift to 2nd gear. The gas pedal should be held to the floor from the beginning until you shift to 2nd.
Step 8: Continue shifting gears accordingly.
that's how i've always done it, and it was good enough to get me and my basically stock IX MR to 12.82 @ 107.41 with only a cat back, no tune, no other power adders, a boost leak, and a possibly slipping stock clutch.
Step 1: Stop
other 2.0 + red
Thanks!
Daniel
other 2.0 + red
Thanks!
Daniel
I've heard of that device before, it's usually referred to as a "WOT box" if I remember correctly. I have no experience with those, so I can't really offer anything in that department. Sorry . Launch control can be adjusted with a tune, so I'm not sure if they're even necessary on an evo.
What about when you're at the staging light...
-Wouldn't it be better to pull the e-brake up to lock up? This also prevents moving off the staging light and having to reload. I'd pull the e-brake up and have the clutch almost to breaking point drop the e-brake slip the clutch hit the gas and go.
Let me know if that would be a bad technique.
I ran a best time of 12.61 at 315 hp maybe less cause i put 100 oct in and turned the boost up without a tune on 100 oct. My afr's were pretty rich on the runs. Now i have a new setup and goin to the track this weekend weather permiting.. Good luck!
Yoo Shin
Cobb AccessPORT
May 25, 2012 08:39 AM
