shifting question
shifting question
alright 2 shifting questions. (im new to it, only been driving stick 2 months)
first off i heard its possible to shift without using the clutch? is this true? how is it done? and has any1 here experimented with it? i dont plan on doing it im just asking for curiosity.
next question is about downshifting.. How exactly do you downshift? I do it but im sure you guys are more advanced know more ect.. what i usually do is if im turning or slowing down at a sign or what not ill throw the car into neutral then guess my gear as im moving which works pretty well... When do you downshift usually? Does doing what I do effect the car in anyway?
thx a lot to all who respond.
Down shifting is lots of fun when you know how to do it well. When approching a turn you put clutch in put car from 3rd to 2nd give the engine a rev to match RPMs with the clutch and then release the cltch.
To answer your first question it is possible to shift with out eh clutch on up-shifts. This requires your car to be at high RPM when you are doing this. It is commonly called power shifting. I have never done it but have read about it when motor trend was using a corvett to do it in.
i dont get it, why would i rev the engine before releasing the clutch...that doesnt seem to make sense for me and how high would i rev? i drive a stock evo 8.. and is this the same for all gears? also whys it fun : D
downshifting is fun cause when u downshift u get that jolt of power and your car will just sorta "cant really explaining the word" go. this is especially fun when turning cause u acceling to the turn u have to slow down to make the turn by downshifting u can exit the turn a lot fast rather than doing it normally. u give it that extra rev while the clutch is down so that when u shift your rpm will be already at give or take 5k when engage it so that u exit at full power. my advice to u is too find a beater to try and learn this cause i cant explain to u how bad the car i practiced on is screwed. if done wrong the clutch will seriously suffer
if you read my 1st post then you would know if i drive stick, i dont downshift rather i shift into nuetral then pick a gear depending on my speed
so downshifting your saying 3rd - 2nd, clutch down ,shift to 2nd, rev high, release clutch?
Rev to match... generally that's high...
If you shift w/o clutch, you can rev and "feel" when it gets to a matched speed. If you're too low, you hear grinding, and if you're too high, it doesn't "slide" into gear. And if you're my Fiance, you grind, and then kill the engine.
Rev Match:
Example... Your Car Turns appx. 3k @ 70mph in 5th Gear.
70mph in 4th gear is roughly 3,900 (I may be off here)... In order to match Revs... you would clutch the car out of 5th, Press the gas until the tach read 3,900 - and then release the clutch with 4th gear engaged.
If you are good with this, you can shift without clutching between these gears, so long as the revs are high enough in your exit gear, and are matched properly to the entrance gear. It works both ways (up and down)...
As for remote start... there are 2 ways to do it without attaching sensors to every gear... 1) If your system has a glow-plug circuit, you could use it to power a relay that makes the car think the clutch is engaged (close the circuit on the sensor).
Or you could get a system that requires you to exit the vehicle with the engine running and e-brake set before it kills the engine. The system then disarms itsself if you open a door before starting the car. Think about it - how do you exit your car with the e-brake set and the engine running while it's in gear.
