Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
E-Brakes Hand Brakes
Old Oct 11, 2002 | 12:48 AM
fat_zilla's Avatar
Question E-Brakes Hand Brakes
is there a way to make your e-brake turn into an actual handbrake? you can use it as a hand brake but you have to push in the stupid button that locks. im just trying to figure out if there is a way to disengage the button, and if you do that is it possible to put it back in so you can pass safety inspections? im havin a hell of time swinging my car around superfast and taking off fast because i cant pull and unlock and shift all at the same time.
Old Oct 11, 2002 | 01:23 AM
cupOZnj's Avatar
first of all, i hope you like changing your tires because if you use the ebrake that often you are going to wear a flat cut in them pretty quickly. if you practice with the ebrake it's really not that hard to put it down with the button. but if you really want to take corners well, you should try heel-toe method. it's much better for your car and works more effectively. plus it doesn't lock up your tires like ebrake. i use to use the ebrake all the time and it wasn't easy explaining to my mother why the tires looked like someone had taken a saw to them.
Old Oct 11, 2002 | 01:26 AM
LBLancerDude's Avatar
heal toe method? never heard that one... explain
Old Oct 11, 2002 | 01:32 AM
fat_zilla's Avatar
i really dont do it that offen to really wear the tires... but im going to start rallying my justy in the dirt. i just want to make it so i can pull up on it to lock the tires long enough to swing the back around without the brake locking... the reason for my locking problem is the brake is hard to unlock... sometimes it takes 2 hands to get it to go back down.
Old Oct 11, 2002 | 02:00 AM
reddog's Avatar
this has been discussed, do a search or look in the driving techniques section of the forum
Old Oct 16, 2002 | 01:35 AM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
I might be way out in left field with this suggestion, but since the Lancers (except the LS) don't have ABS, couldn't you just lock the tires with the foot brake? And the heel-toe method would keep you on the gas if you needed it. Not that I've tried this, or even rally racing, but I think that would be just as effective.
Old Oct 16, 2002 | 01:38 AM
Moderator
Bomb Squad Unit #02
OOOPS! Now I read your thread completely and saw you weren't talking about driving a Lancer, so I have no idea about how a Subaru drives.
evodude32
Apr 9, 2016 01:01 AM
Grimgrak
Aug 13, 2014 09:24 PM
740 Turbo Brick
May 7, 2014 06:37 PM
R/TErnie
Feb 10, 2013 07:26 PM
GGP Wolf
Mitsubishi TC-SST Discussion
21
Feb 14, 2011 05:44 PM
