DynoFlash [Visit Site]
Results: Before and After 272/272 HKS cams
Old Dec 17, 2004, 08:00 PM
TD05HR's Avatar
hey
this is the dyno charts before the cams(272/272)
Helix T-Back w. test Pipe
Buschur Intake(cone only)
Hallman MBC(@21psi)
walbro pump
custom tune..
304WHP
after, w. HKS 272/272 Gears = -4/-1
custom tune
boost was a little higher @21-22psi
336WHP
its not even the max power i'm pointing out here...its the way it gain in the mid-range and how the power level itself uptop unlike the stock cams..
Another good tune by AL..Thanks man..
Old Dec 17, 2004, 08:02 PM
Jon H's Avatar
edit: nevermind.
Nice! I like those gains @ 4.5k rpms, looks to me 50whp!
Old Dec 17, 2004, 08:05 PM
eve-slow's Avatar
So did you add HKS cam gears with the cams? How is the idle?
Old Dec 17, 2004, 08:12 PM
TD05HR's Avatar
idle is not to bad...its alot better, w. out it its really bad..like it wanna die and jump up and down very quick., w. -4/-1 its alot better, still jumps up and down, but it doesnt stall or anything...blah!!
Old Dec 17, 2004, 08:53 PM
Registered User
evoego's Avatar
looks like anywhere from 25 to 45 hp difference at all RPM levels. Nice, beat you can really feel the difference.score another .4 of the 1/4.
Old Dec 17, 2004, 10:21 PM
JTB
JTB's Avatar
Do you have any graphs that show torque changes?
Old Dec 18, 2004, 07:50 AM
DjRiice's Avatar
question...what did u run in the 1/4 b4 your cams......b/c thats is the set up im looking to do soon, and i was wondering what i could expect??
Old Dec 18, 2004, 08:11 AM
LuxuryBroker's Avatar
Al, if running the 264/264 set up with cam gears, what would I set the gears at(-2,-2 or -4,-1 ect...)
Old Dec 18, 2004, 09:16 AM
htsai14752's Avatar
yes im curious abuot this too. planning on running 264/264 with hhks cams
Old Dec 18, 2004, 09:24 AM
EVOTEXAS's Avatar
Hmm, first pull in July, second pull in November. A temp change like that affects my race car by about 30 HP. I hope you realize that you did not gain 30 HP from just cams. Half of that was cooler air.
Old Dec 18, 2004, 11:59 AM
boostfed's Avatar
Evotexas: go check ot some of Noize's dyno graphs from his addition of cams as cam gears. his where all done on a DD dyno. If I'm not mistaken he actually made more power with the cam gears then the cams. it was like a 15-20whp with the cams and 20-25whp with the Cam gears. this was also tuned with an Xede. So, they're pretty acurate figures.
-Chad-
Old Dec 18, 2004, 02:28 PM
EVOTEXAS's Avatar
-Chad-
I also have cams. I know what they give for gains. I also do not have cam gears because they do not do much more than shift the powerband. I have seen where Noize says he gained a bunch of power with cam gears and you know what I think? I think his timing was way off and it got fixed when he did the gears. That doesn't seem to be uncommon with the Xede setups around here either. How could Noize be the only person in the world to gain that much with just cam gears? Common sense says no.
Old Dec 18, 2004, 02:39 PM
boostfed's Avatar
I might be wrong, but I think he might have actually done cam gears first and then the cams next. his car started out as just a normal stage 1. the stage 1, consist of tb exhaust, cam gears, and the Xede... trust me. I'm not trying to start anything. Just putting my 0.02 cent in.
-Chad-
Old Dec 18, 2004, 02:48 PM
EVOTEXAS's Avatar
-Chad-
I know man it's cool. I just really think something was wrong with his timing or car first. Noize has the only car in the world that picked up more than 5-10 HP with cam gears. Hardly something I would consider valid or repeatable when buying parts. Just my 2.
Old Dec 18, 2004, 03:21 PM
DynoFlash's Avatar
Cool ! Evotexas and I agree 100%
Quick Reply: Results: Before and After 272/272 HKS cams
