My Stroker engine lives !
Originally Posted by BBYBruno
So Al you've given up on the 2.0L? So now your moving up to a stroker, for more power?
I mean AMS is still moving forward with a 2.0L and getting great results.
I am doing my own thing and I have different goals at this time
Maybe next year a GT42 may be in my plans - who knows
At this point I was shooting for a set up that could run consistant and reliable high 9 second passes and with the turbo I am currently using the GT40 was not really working out well on the 2.0 L and I thought that it may work better on the stroker
My idea is a car which can go 9's but which is also very enjoyable and streetable on the road.
Also - I think that for my customers on the street who are not drag racers a stroker is going to be a very popular and upcomming evo modification
installing, tuning and testing a stroker on my own evo is the fastest and easiest way for me to accelerate my own learning curve on stroker set up and tuning
As I am going forward, I will be posting up details and data here for those who may be interested
Originally Posted by nefblkevo
what are the trade offs between a built 2.0L vs. a 2.4L?
The 2.0 has a much higher upper rev limiter and will make more power at high rpms due to physical science of piston speed
The 2.2 and change a/k/a stroker generates more low end grunt, gets the turbo spooling faster but gives up upper rpms capacity due to the ultra high piston speeds it generates at high rpms
originally Mr. Buschur told me lasy year 8,000 as a reliable rev limit which ruled it out for my racing as I must go about 8,600 rpms in 4th gear at the track
However, over time Mr. Buschur has pushed these motors harder and harder and they have gone well over 9,000 rpms with no ill effects (DON'T TRY THAT STUNT AT HOME)
This great news combined with the fact that there has been no reported failures of any Buschur storker kit got me thinking to give one a try
After I drove a customer's car which had a complete Buschur stage 4, GT35R and stroker on the street and was chirping all 4 tires shifting gears that is when I decided to give it a try
I intend to explore the limits of what it can do and how it does it
i just wanted to add that my short block I ordered from Buschur is a 100% standard stroker that they sell to anyone.
The ONLY modification I added was to o-ring the block
Originally Posted by gsnt
Al, do you have any intentions of going to NDRA Norwalk? I'd like to see as many DSM/Evo's as possible in T4. Show the Honda boys whats up!
poor hondas !
Al, a couple more questions.....Ive heard using o-rings on the block is a bit of a double edged sword...extremely durable, yes, but in the event something goes wrong, the first thing to take the hit is going to be the piston, not the head gasket. Just curious what your thoughts are.
Secondly, standard oil? Ive heard you change your oil like once every two weeks or something like that....so I can see why standard oil is sufficient in saving costs.....just curious as to that also. Let us know when you get it fired up and tuned to race.
Its the rod bearings that dont seem to last an entire season so I will start changing them every 4 races.
I change the oil after every time i drive the car
