flex fuel on stock ECU coming soon...
#33
I was thinking of using theTephra v5 to run one e85 map and then what would be cool is to have the flash cel on knock mod be able to trigger a switch from map a to map b instead of the cel light. Could Tephra wire code to do this?
this has lots of different possible applications.
regardless I am really happy that there will be a E85 within 3 miles from where I work
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
#34
So you want it to switch maps when you get knock?
Don't forget, E85 is a FARR richer AFR than pump gas so if you plan on using E85, you'll be needing larger injectors if you dont have them already. Its roughly a 9.7:1 AFR for stoich and around 7:1 for WOT boosting (if memory serves me).
#35
I cant wait till this is finished that still sucks about tephras car hope he gets it all figured out soon wish i had the cash now to donate and help him out
BTW how big of injectors i was planning on going 725 to achieve the horsepower i want roughly 500-550 would i need bigger if i ran E85?
#37
I'd recommend 1000cc's for 650 crank HP like you are shooting for....but thats for regular gas. Most HIGH HP guys running E85 probably use a secondary injector setup (4 additional injectors) for daily drivers so the idle is more controllable. You'll see people running high HP E85 cars with 600-750cc primary injectors and 1000-1200cc secondary injectors which only come on when boosting.
#38
wow really crazy i should stop listening to the guy i use to he told me that for 550-600 at the wheels that 725 would be good lol i should try to commit the formula for figuring out which size to use to memory
#39
#41
R33E8
Mar 23, 2017 05:09 PM
tscompusa
10
Dec 12, 2016 10:32 AM
mrfred
E85 / Ethanol
148
Apr 17, 2015 07:56 AM
