E85 vs. 100 octane
Old Jan 21, 2008 | 10:24 AM
lexat20's Avatar
E85 vs. 100 octane
I am looking to retune this spring on either E85 or 100 octane. A local gas city carries both but I would like to hear your feedback as to which will make more power.
The car has all the bolt ons plus 272's and a Green turbo. Currently I use 93 + meth and the car dyno'ed 348hp/373tq. This was on the stock turbo. I am hoping to clear 400hp/tq. The car will mainly be used for road racing, not a daily driver.
I like the idea of E85 and more gas stations are carrying it which will make it easier for me to fill up. If I use the 100 octane then I have to monitor the tank much closer to be sure I am not stuck in BFE looking for high octane. The downside to E85 is that I will need to run a second walbro.
What does everyone think will gain the most power?
Old Jan 21, 2008 | 01:24 PM
lexat20's Avatar
help?
Old Jan 21, 2008 | 01:30 PM
steexz's Avatar
Well for a little help, I had similar mods, buschur TBE cosworth M2's and the rest of the bang and on a dynojet i was at 396tq on the stock turbo running 100 octane at 28psi spike. e85 is from what i heard is like 105octane or 109... so i would think e85 would be better. But your right, you have to run a double pumper and probably 1200cc injectors with the green. Im looking at running a 3065r with e85 so i have to do a lot of research.
Old Jan 21, 2008 | 01:37 PM
mplspilot's Avatar
E85 is better than 100 octane gas.
Old Jan 22, 2008 | 11:50 AM
turbo271's Avatar
+1
Old Jan 22, 2008 | 01:12 PM
Mirage2.0's Avatar
Sh*t, I wish I could get 100 or e85 in Long Island, NY. I'll take any.
Old Jan 23, 2008 | 05:18 AM
turbo271's Avatar
I'm lucky. I have like 5 within a 10 mile radius.
Old Jan 23, 2008 | 11:49 PM
skiracer's Avatar
e85 can take more timing advance compared to 100
Old Jan 24, 2008 | 02:05 PM
lexat20's Avatar
This is the kind of info I was hoping to hear. Thanks. Anybody else?
Old Jan 25, 2008 | 12:38 AM
skiracer's Avatar
You don't need a double walbro, unless you're pushing a serious amt of power (drag racing setup?) . They recently tuned a 2.4L gt35r hybrid turbo with 1000 cc injectors and a single walbro. Made 500+whp. THe injectors got maxed out, but fuel pump was sufficient:
http://www.socalevo.net/forum/index.php?topic=53637.0
Old Jan 25, 2008 | 12:39 AM
skiracer's Avatar
My tuner said you can increase timing to something similar to 110 leaded race gas. on my Stage 1E RRE setup, timing was advanced 9 degrees over my 91 octane tune.
Here's my personal experience with E85:
http://www.socalevo.net/forum/index.php?topic=54164.0
Old Jan 25, 2008 | 05:54 PM
RazorLab's Avatar
9 degrees across the board?
Old Jan 25, 2008 | 05:55 PM
skiracer's Avatar
dunno, i don't know much bout tuning, so that's why i let my tuner play with the laptop.
Old Jan 25, 2008 | 06:33 PM
konad's Avatar
You 100% sure on that? I thought that when running e-85 you needed ~20% more fuel then premium gasoline and anything over a stock turbo would require more then just a standard walbro 255.
Old Jan 25, 2008 | 06:42 PM
skiracer's Avatar
a single walbro ran fine on his car, but if you want to be safe, you can do a double pump. He was only pushing 25psi however... If he cranked up the boost more and had larger injectors, a double pump would probably be needed on his car.
Quick Reply: E85 vs. 100 octane
