High volume fuel rail needed for E85?
Old Apr 2, 2008, 04:16 PM
mrfred's Avatar
With the need for 1000 cc/min injectors and a Walbro fuel pump, it seems that E85 requires very high fuel flow volume. Is there any need to upgrade to a larger volume fuel rail to deal with the pressure drop across the fuel rail when 1000 cc/min injectors are operating at 100% duty cycle?
Old Apr 2, 2008, 04:43 PM
[EVO]Cookie's Avatar
I changed the fuel rail to reduce lean conditions cased by the small bore of the stock rail. Also the fuel pressure regulator so I have the proper pressure for my injectors because it's a math calculation on fuel pressure. I replaced the full fuel line to 3/8 methanol braided fuel line.
Old Apr 2, 2008, 04:45 PM
mrfred's Avatar
Did you replace both the high pressure and the return line? And for whichever/both, you replaced the entire line between the fuel rail and the gas tank?
Old Apr 2, 2008, 04:47 PM
All the lines.
Old Apr 2, 2008, 04:48 PM
I"m using the 100PSI fuel hose. I thing stock lines are 50PSI but I cant remember right now.
Old Apr 2, 2008, 05:08 PM
mrfred's Avatar
All the lines.
How much hassle was that? Where did you buy the lines?
Old Apr 2, 2008, 05:10 PM
You also need to bump up the fuel pressure about 10% for E85 due to the fuel density difference. I use 45PSI at the FPR at idle with a 1:1 rising rate on 93 and almost 50PSI with E85. 1000 cc injectors.
Old Apr 2, 2008, 05:12 PM
It's no hassle to me better safe than sorry. I purchased the lines from a Race shop near where I work. They are Aeroquip lines.
Old Apr 2, 2008, 05:15 PM
I don't think the Evo metal fuel line are nickle plated which means they will corrode over time. I open my tank up every year to check for corrosion.
Old Apr 2, 2008, 05:16 PM
Turbojunkie's Avatar
all of that so far had been proven unnecessary.
Old Apr 2, 2008, 05:22 PM
mrfred's Avatar
The hole in stock fuel rail is not very large diameter. I'd be interested in seeing any documentation showing a minimal fuel pressure drop across the fuel rail at high IDCs with 1000 cc/min injectors.
Old Apr 2, 2008, 05:23 PM
Proven to you maybe but not me. I don't like to take chance especially when fuel component failure can result in fire.
Old Apr 2, 2008, 05:25 PM
stock rail bore is .192 and I have the Perrin .632
Old Apr 2, 2008, 05:31 PM
frenchy99's Avatar
You make a good point. Better fuel flow= more consistent power, better spark, just to name a few.
While you are at it, upgrade to a 65mm tb.
Old Apr 2, 2008, 05:32 PM
Billy@EnglishRacing's Avatar
it is not needed
Quick Reply: High volume fuel rail needed for E85?
