What you Need for E85?
Ok so I see a lot of threads asking what you need... I also would like to know.
What are the minimum Upgrades for E85 and What are the recommended/Ideal upgrades
thanks
and maybe a thread....not thins one but one like it should be "sticky"
thanks
that's what I'm saying instead of reading through a million threads. Make a sticky topic on the definates. Then the Optimals. So people don't spend 30 hrs trying to decipher 50 threads into something useful
Here is a thread I started, hope this helps you.
https://www.evolutionm.net/forums/sh...d.php?t=277788
This depends on your setup, but with a stock turbo you are going to need a walbro pump, at least 1000cc injectors (I would go with 1150cc because you don't sacrifice driveability, but have room for upgrading) and a way to tune it. Of course if you are talking a bigger turbo then a second inline fuel pump with a way to regulate the pressure will probably be necessary.
I have a 35r with 272 HKS cams and use 1150cc FIC injectors, a walbro 255 in tank, a walbro 392 inline and an aeromotive fuel pressure regulator with an AEM to tune it. With all this I run about 29-30psi @ 8500 rpm @ 93% injector duty cycle with an 11.5-11.7 a/f ratio. Hope that gives you a baseline to go off of.
PalmTreeZ
Apr 9, 2017 12:44 PM
abosoxfan4life
Nov 17, 2015 06:15 PM
