Flex Fuel Sensor
i have had search alerts set up on ebay for these for about a year now, and as some of you already stated, they are consistently selling immediately for over $350 now. at least i know i'm not the only one wondering where to get them, and for less.
I have the Serbian gauge that displays it's output, but not the sensor.
when you say "working" do you mean hooked up with a usable output signal, or "working" in the sense that your ECU will make adjustment based on the output signal by itself? i know for a fact that people have it hooked up, powered, and are using its output, but AFAIK the true flex-fuel patch for our cars is still in development by private parties. to To *try* to answer your question, YES, it *should* be possible, but we don't know for sure yet
I would be willing to pay for something like that. Even if a standalone needed to be converted.
I ran e85 for about 8 months. It was a hassle always keeping my laptop with me and keeping it powered. (In Houston, Tx)
Now I'm in louisiana, we only have 1 pump.
Im really waiting for the microfueler to come out.
Do you tune the high octane map for e85? then tune the low octane map for pump?
How would this work with such a huge difference in fuel needed?
There are alt maps for fuel, timing, boost, and I think injector scaling.
Forgot to mention that of course high flow injectors and a Walbro fuel pump are needed for a stock turbo. For more than a stock turbo, even more fuel flow capability is needed.
Eventually I want to try just having about 4-5 different maps on a laptop, the GM sensor hoooked up to the Serbian fuel comp. gauge, and just load different maps depending that i'm seeing on the wideband and fuel comp. gauge, and turning the MBC accordingly. Regarless of your setup, even with true map-switching on the stock ECU for flex fuel, you will probably still have to adjust boost manually right? A GM BCS and appropriate pre-set boost tables for each of those fuel maps would be even more ideal. I know the auto map switching itself is not even ready yet, but is this a possibility?
Im going to have to download the patch then and look into it further for my evo 9.
Ethanol fuel is great!!
Im trying to find a way to make it right now. Im looking at buying a ethanol still.
