P0300 and E85 ???
You could simply do a log of your car after warmed up and maybe a drive to see what your fuel trims are. Some say the fuel trims should be within +/- 3 and others say 5. .... For me I was getting p0300 and and 304's for a long time and my trims were within plus minus 2. I finally figured it out and it was during warmup the car would run like crap. I ended up changing the RPM's at warmup upward to compensate and no more codes. Sad part is I will have to look at current ROM to see even which part or even the name of the table that was changed it listed RPM by temp. expressed in celsius I believe
bringin it back to life...
Just switched over to E-85 (possibly E-70) recently, and just got my first p0300. Happened @ cold start this morning.
Is 14*too much timing in the idle region (stock cams)? or Im thinkin my trims off...
Gonna work on it tomorrow. Im also workin on the alt. cranking IPW stuff...
Does this look right w/ RC 1000's?
240.3
122.1
60.1
31.3
28.4
21.4
4.7
240.3
122.1
60.1
31.3
28.4
21.4
4.7
