Max power on Lucas 120lb running E85?
Thanks
I am currently running 517 whp (Dynapack) on a single Walbro before going lean on pump fuel. Have upgraded to twins, but will upgrade further if thats is not enough.
Current turbo is a 3582R 0.63, but have a new HTA3582 0.82 which will be mounted.
Enginemanagement is Vi-PEC (dont see how a different ecu will affect the max output from the injectors)
Tuner is me.
Dynoroom temperature about 20 degrees celsius
I know that different engines have a different BSFC, but based on your experience, 120lb injectors will lean out at mid 500 on E85? I was hoping to break the 600 whp barrier....
Thanks
Tuner is me.
Thanks
The Lucas 120lb. injectors have been flow tested by FIC at around 1130 cc at 43.5 psi. These ratings are similar to RC 1200's and both will probably flow 1260 approx. at around 50 psi I suppose they would support 500
Data borrowed from RC engineering site
Flow Rate - CC's:
1200 CC's / MIN @ 55 PSI
1090 CC's / MIN @ 43.5 PSI
Flow Rate - LB's:
114 LBS / HR @ 55 PSI
104 LBS / HR @ 43.5 PSI
Flow Rate - CC's:
Flow Rate - LB's:
RalliArtEvoVIII
65
Aug 5, 2005 08:32 PM
jmartinez1170
62
Jul 19, 2005 06:31 PM
