excessive knock on e85
Old Mar 9, 2010, 06:13 PM
jid2's Avatar
Or have someone check the runout of the lobes and see if they are straight like Brian was talking about.
Old Mar 9, 2010, 07:10 PM
donour's Avatar
I'm not sure if it is worth it. I'm not quite to the point where I want to pull them out, but if I do and find that the stock cams eliminate the problem then the cause because purely academic.
d
Old Mar 12, 2010, 07:59 PM
donour's Avatar
Update:
The Accel Enrichment vs. Temp table doesn't affect the knocksum.
I finally bit the bullet and played with the knock control tables. I raised the low multiplies by 3 (to 16) and the mid by 2 (to 20). I then raised the load value to 120 @ 2500 and 95 @ 3000,3500.
That caused basically all of the free-revving knock counts and the persistent ones that I get under light throttle to go away. Maybe it _is_ just valve train or drivetrain noise. *shrug* I do have aftermarket motor mounts.
Did I just set myself up for catastrophe? Will those small changes have a big effect once I load the car up on track? In those load cells I'm running the stock timing values on E85, although I'd like to run some 91 occasionally too...
d
Old Mar 15, 2010, 08:28 PM
donour's Avatar
update:
I drove around today while listening with detonation cans . I didn't hear any knock, just a rhythmic combustion sound and a little bit of valve train noise in the background.
I'm curious what folks think about my change to knock sensor tables...
d
Old Mar 15, 2010, 08:36 PM
Evoryder's Avatar
I upped mine awhile ago. Phantom knock is a pain...big cams, stiff mounts...etc = knock
nj1266
Feb 18, 2024 07:41 AM
PIE-R
Dec 21, 2019 08:14 PM
ehall20
Apr 5, 2014 05:26 PM
David Buschur
Sep 16, 2013 08:26 AM
blk-majik
23
Aug 16, 2012 04:20 PM
Quick Reply: excessive knock on e85
