Dispelling some ethanol myths...
I've got a running thread on another forum, but here are my current tests/findings.
Test one-I've got a full drum of E83 in my garage that I filled/sealed in mid Sept. The date is on the drum. I'm going to test the ethanol content in April to prove it's still the same. Sample will be taken from the bottom of the drum, as that is where any moisture would accumulate. The garage is heated, but the heat is often off several days at a time. Temps from -20 to +70 will be had.
Test two-Similar scenario, but with only 18 gallons in the drum. Was last openend in early November. I'll test it at the same time and in the same manner to see if any moisure has been absorbed.
Test three-I've got a 5 gallon can 1/2way full of E83 stored in the same garage. Same deal/testing
Test four-Water bottle 1/2 full of e83, with the cap off. This should be the worst case scenario for storing E85. Same deal/testing..
Test five-1/2 full clear jug of E98. Same deal/testing
test six-Full jug of E98. Same deal/testing
I sampled the aforementioned can with E83 in it (test three) yesterday, and it was still testing at E83. The fuel was placed in the can in mid September.
The test is costing me nothing as it's my fuel to start out next season with (we don't get the higher content until mid May). Figured I'd actually document it for the people that believe anything they read on the net.
Nice testing.
I was given a 20L Jerry of E85 by a mate that had sat sealed in the back of a garage for ~18months with a ~20*C temp fluctuation.
Tested at 85% three times.
1) When the fuel is dispensed from the plant or holding facility and dispensed into rail car or truck and the difference in temperature causes if to condensate. Rare and minimal water is produced. (ounces)
2) The most common way to get water in fuel is from fill tube at the service station. If the lid that covers the service hole and the fill tube cap is not sealing correctly, rain water will accumulate in the service hole and seep its way into the fill tube. (amount depends on leak)
There have been issues with black algae with underground steel and older single wall fiberglass tanks with corn fuel. Here in California, steel and single wall fiberglass tanks have been disposed of since 2010 and all new tanks have a anti-growth spray applied to them to help prevent the growth of organic matter.
David Buschur
56
Jul 1, 2014 09:57 AM
David Buschur
E85 / Ethanol
98
Mar 20, 2012 06:03 PM
