Tuning Over 350 Load
POSTED IN ECUFLASH SECTION INSTEAD. PLEASE DELETE.
I'm hitting different loads higher than 350 that need adjusted to maintain my target AFR in different gears, particularly 6th gear and was wondering what the best way to adjust for this is. Should I change the X axis on my 3D VE Table or should I just make the adjustment in my fuel map or is there another way to go about it? I've been trying to make adjustments to my VE Table so I hit the AFR I specify in my fuel map but need more resolution at over 350 load and wasn't sure the best way to handle this?
DynoFlash
Aug 12, 2007 07:15 PM
