Injector scaling and latecy for different injectors.
Old Nov 30, 2007, 08:59 AM
  #256
Jorge T's Avatar
All breather hoses are connected, running OEM bc solenoid and stock airbox. I made a painstaking effort to get the injector o-rings seat properly in the manifold. I do have HKS 264/272 cams and a ported hotside evo 9 turbo.
Originally Posted by Oracle1
You are better of lowering your 14v.
would this make idle leaner and ltft lo go positive?
Old Nov 30, 2007, 01:10 PM
  #257
Oracle1's Avatar
This should keep the idle there but make the mid less.
Old Nov 30, 2007, 01:53 PM
  #258
Jorge T's Avatar
i'll try this tonight
Old Nov 30, 2007, 02:42 PM
  #259
Oracle1's Avatar
With bigger cams, when adding more timing at idle to stabilize it should the fuel cell at the same point be incresed too? If so, what is the rule here?
Old Nov 30, 2007, 02:59 PM
  #260
EvoM Moderator
joedr's Avatar
Thumbs up
On my case, I advanced the timing to 7 and it idles very fine.
I think that the car is in close loop and will try to hit 14.7 AFR by itself. I would leave the idle fuel cells as default (14.7). If you get lean/rich conditions.... then it is a matter of fine tune your scaling and latencies.
BTW.... I am on PTE 780s (I posted my settings on this thread) and the car fluctuates from 15.5-14.3 at idle with and w/o AC. I am on GSC S1s!
Hope this helps!
Old Nov 30, 2007, 04:50 PM
  #261
Jorge T's Avatar
lowering latencies@14v made ltft mid stay at -7.8 and made ltft lo go to +11!
scaling of "PTE 680" <(said on box) at 622 and latencies at
4.69 3.624
7.03 1.992
9.38 1.344
11.72 1.008
14.06 0.768
16.40 0.600
18.68 0.456
LTFT lo+1.6 /LTFTmid -3.5 and it's staying like this
Old Dec 1, 2007, 05:32 AM
  #262
Oracle1's Avatar
Sorry...
Log it again after a few weeks, they will change again. Worth checking they do not fall outside +- 13.
Old Dec 1, 2007, 06:40 AM
  #263
dan l's Avatar
This is for FIC 1000cc/min injectors. I wanted to drive the car around and start it in sub freezing weather before posting up my values. Car starts up and idles fine in all weather conditions. This is for a DSM but the code is exactly the same on the evo and the values will transfer over. I do not use a stock O2 sensor though, my ecu talks to my LC1's wideband signal for closed loop cruising. So if anything my trims should be more accurate/consistent than a stock narrow band sensor.
4.69 4.371ms
7.03 2.427ms
9.38 1.467ms
11.72 1.155ms
14.06 0.963ms
16.40 0.867ms
18.68 0.771ms
For the global you have to do some math. My base fuel pressure is 56psi. Higher fuel pressure is not a linear relationship with respect to flow. Thus 56/43=1.3. Then you take the sqrt(1.3)=1.140 and multiply this by my rated flow of my 1000cc/min at 43psi to get 1140cc/min. I set my global to 1150cc/min. So for an evo at 43psi base you would take your stock global injector size and multiply it by x when [new inj size/number in ecuflash]=x. If you have higher than stock base fuel pressure you must do the math above.
In the end it is fairly plug and play with a little math and those latency numbers. Like I said my **** starts up and idles in 20 degree F weather with very large cams and large valves. It can sit and idle for half an hour on end, cruises well, and returns 30+ MPG. For the most part, it drives better than stock.
I know of someone running 1600cc/min injectors on the stock ecu but don't know their values, sorry. I just know its easily done.
Old Dec 1, 2007, 08:33 AM
  #264
Jorge T's Avatar
Sorry...
No worries...I've been checking for some weeks now and it had settled at lo+5/mid-11 and during looong datalogs I could see the stft go negative during cruise and go positive during idle until it settled to the values above and stft would just hover +1/-1 telling me it had "Adapted" to maintain stoich in closed loop. At least this is how I'm interpreting this.
At these new settings I can tell that drivability in traffic has improved greatly, idles like stock at stoplights(no more idle 17:1 AFR swings) and the herky jerky during partial throttle transitions disappeared. The jury is still out...still got to go redo open loop.
Old Dec 3, 2007, 09:10 PM
  #265
ixbreaker's Avatar
hmmm....14 volts is pretty high...whenever i log my evo ix it's avg 13.78 idle and 13.6 cruise....maybe there's sumthin wrong with my car? i've been scaling denso 720's for about a month now...and the closest i got it was lo +1 and mid -3....scaled @ 622
Old Dec 3, 2007, 11:00 PM
  #266
TTP Engineering's Avatar
Dude, +/- 7% is perfect.
Old Dec 4, 2007, 02:11 PM
  #267
ixbreaker's Avatar
i guess i'm ****.. o and thanx for helping me fix my zeitronix lcd screen...TTP great customer service
Old Dec 15, 2007, 07:32 AM
  #268
Ph3n1x's Avatar
Anyone got Scalings and Latencies for PTE 880s
Cant seem to get the Cruise Trim to level out from being too rich.
Old Dec 15, 2007, 08:15 AM
  #269
EvoM Moderator
joedr's Avatar
880:
scaling:770
3.312
2.304
1.392
1.008
0.792
0.600
0.504
Just comment on how close they are from yours! It was used on a friend's car!
Old Dec 15, 2007, 08:25 AM
  #270
Ph3n1x's Avatar
A little higher voltage than what I used and also the Scaling is higher.
Ill give it a try.
Quick Reply: Injector scaling and latecy for different injectors.
